-   -   First time engine drop (http://forums.pelicanparts.com/porsche-911-technical-forum/620818-first-time-engine-drop.html)
Brown747 07-23-2011 08:01 AM
Engine is coming out for a broken head stud, SSI's , reseal, de-smogging, and a growing list of "while its out" items. Followed Wayne's book and all was straight forward.
Thor
http://forums.pelicanparts.com/uploa...1311432268.jpg
http://forums.pelicanparts.com/uploa...1311432292.jpg
http://forums.pelicanparts.com/uploa...1311432333.jpg
http://forums.pelicanparts.com/uploa...1311432406.jpg
Targalid 07-23-2011 08:12 AM
It was that clean BEFORE you took it out?
wholio94112 07-23-2011 10:20 AM
...good on you, man...i know you enjoyed that sierra nevada!!!
Brown747 07-23-2011 07:02 PM
Today a little clean up before going after the studs. Mineral spirit rub down then blasted off with the pressure washer. Exhaust was removed without breaking any studs. Heated the nuts to red hot with an oxy/acetylene torch and they came right off.
http://forums.pelicanparts.com/uploa...1311472683.jpg
http://forums.pelicanparts.com/uploa...1311472754.jpg
Gustyones 07-23-2011 07:54 PM
Congrats. Keeps us posted. Just curious, what kind of jack is that?
Brown747 07-23-2011 08:54 PM
The motorcycle/ATV jack was something my dad had laying around his shop. Probably a HF product from 10+ years ago. I had it support a furniture dolly which supported the heat exchangers and also used my floor jack under the transmission support to aide in achieving the right angle during the drop.
http://forums.pelicanparts.com/uploa...1311479566.jpg
dondarnell 07-23-2011 08:56 PM
Wow, did you get it that clean with just mineral spirits and a power washer?
tldry 07-23-2011 08:57 PM
Nice work Thor! I need to get over there and learn from you.
DRACO A5OG 07-23-2011 08:57 PM
Hot Damn that is a Great Clean Up, I am humbled!
rusnak 07-23-2011 10:43 PM
Lookin really good!
Brown747 09-24-2011 07:28 AM
Progress report
I've had some time to work on the car lately so here is a little update. Engine was stripped down to the studs and all lower Dilivars replaced with steel. http://forums.pelicanparts.com/porsche-911-technical-forum/622847-broken-head-stud-defeated.html Cylinders are back on and I'm waiting for the baffles to come back from powder coating. Cleanup of the engine bay and new sound pad installed. Bilsteins have been sent off for rebuild. I met up with Ed M , aka Ivangene and had him put in a set of his Derlin bushings in my shift coupler, Thanks Ed!
http://forums.pelicanparts.com/porsche-911-technical-forum/624546-christmas-came-early-d-derlin-shift-coupler-ala-ed-m.html Picked up a 2 out Monty to go with my SSi's. I'm not sure I want to go this route yet but it sure is a thing of beauty. The PO had cut the outlets off and had them rotated up for his early car so I'll have to cut them and rotate them to clear the SC bumper. I'm hoping I can get this thing back together before the rains set in! Cheers, Thor
http://forums.pelicanparts.com/uploa...1316873955.jpg
http://forums.pelicanparts.com/uploa...1316873265.jpg
http://forums.pelicanparts.com/uploa...1316873352.jpg
http://forums.pelicanparts.com/uploa...1316873650.jpg
http://forums.pelicanparts.com/uploa...1316873392.jpg
http://forums.pelicanparts.com/uploa...1316873481.jpg
http://forums.pelicanparts.com/uploa...1316873526.jpghttp://forums.pelicanparts.com/uploa...1316873818.jpg
http://forums.pelicanparts.com/uploa...1316873863.jpghttp://forums.pelicanparts.com/uploa...1316874141.jpg
arbita1 09-24-2011 10:34 AM
How did you get the shroud like that?
Brown747 09-24-2011 11:35 AM
Shroud Krylon overhaul
Matt,
I degreased with mineral spirits. Wet sanded with 220 grit. Final rub down with acetone then applied a couple coats of Krylon gray primer. Color coat is Krylon Banner Red applied in several light coats until I had good coverage and then one good coat to blend it all in.
HTH Thor
http://forums.pelicanparts.com/uploa...1316889231.jpg
http://forums.pelicanparts.com/uploa...1316889264.jpg
http://forums.pelicanparts.com/uploa...1316889296.jpg
Brown747 09-24-2011 11:41 AM
http://forums.pelicanparts.com/uploa...1316889655.jpg
arbita1 09-24-2011 11:47 AM
Looks great. Will the paint hold up to the engine temps?
JJ 911SC 09-24-2011 02:17 PM
Originally Posted by Brown747 (Post 6272560)
How much shipped to 13669 :)
schumicat 09-24-2011 02:21 PM
it does look awesome but I'd be concerned about the heat too...giving off fumes etc. I'd use engine primer and engine paint.
Brown747 09-24-2011 02:28 PM
Not going to sweat it... If it doesn't hold up I'll redo it when I drop it for carburetors ;)
Brown747 09-25-2011 05:59 PM
915 cleanup
Spent most of today with a toothbrush, mineral spirits, and the pressure washer.
I'm running out of things to clean up. Must be time to start putting things back together.
TJ
http://forums.pelicanparts.com/uploa...1316998606.jpg
http://forums.pelicanparts.com/uploa...1316998640.jpg
http://forums.pelicanparts.com/uploa...1316998670.jpg
http://forums.pelicanparts.com/uploa...1316998698.jpg
efhughes3 09-25-2011 06:33 PM
Nice work!
