-   -   First time engine drop (http://forums.pelicanparts.com/porsche-911-technical-forum/620818-first-time-engine-drop.html)
timmy2 12-18-2011 06:09 PM
Very nice work Thor,
We both started our engine drops around the same time.
I see you removed the mounting post on the middle runner for the fan mount.
I was going to do that but it was in the right spot to mount the vacuum switch going to the WUR on mine without re-doing my lines again. Where did you attach yours. I can see the lines dropping behind the #3 runner but can't make out where it is attached.
You can see it in my picture from my car. (Ignore the stainless airbox)
Originally Posted by timmy2 (Post 6420845)
Brown747 12-18-2011 06:52 PM
thermo valve relocated
Dennis,
I shaved the mounting pads off intake runners 2 and 3 for the fan mounting bracket and removed the unused one on #4 in an effort to clean things up a bit. I moved the thermo valve behind #3 and used a spacer and a bolt to mount it to the throttle linkage pad. There are 2 tapped but unused holes in that pad that will accept an 8mm bolt. Mount it high enough to clear the throttle bellcrank. Your engine is looking good also!
Thor
http://forums.pelicanparts.com/uploa...1324262779.jpg
Brown747 01-04-2012 02:51 PM
Clean up continues...
Preparation for engine install continued on this warm and wet northwest day. Pressure washed the back end...up next tunnel fuel line replacement, clutch cable, and brake hoses and fluid flush....
http://forums.pelicanparts.com/uploa...1325716865.jpg
http://forums.pelicanparts.com/uploa...1325717293.jpg
http://forums.pelicanparts.com/uploa...1325716898.jpg
http://forums.pelicanparts.com/uploa...1325716944.jpg
http://forums.pelicanparts.com/uploa...1325716972.jpg
RWebb 01-04-2012 02:58 PM
you are smart to replace the rubber brake hoses
I am not real fond of your front wheel "chocks" tho
have a friend there & have them hold a cell phone, ready to dial 911 just in case...
wildcat077 01-04-2012 04:00 PM
Hey Brown,
May i suggest "choking" your front wheels like this ...
I just used some scrap 4x4's and 2x4's i had laying around,and you don't have to raise the car as high in the rear and it keeps the front spoiler off the ground !
If you have a friend with an engine hoist,you can lift the car by the engine mounts then you just lower it onto the engine.It's way safer that trying to jack it up the conventional way with your jack stands extended all the way...
I did the whole R/R by myself and it was a piece of cake,it was my first time as well !
Cheers !
Phil
http://forums.pelicanparts.com/uploa...1325720982.jpg
http://forums.pelicanparts.com/uploa...1325721007.jpg
http://forums.pelicanparts.com/uploa...1325721146.jpg
http://forums.pelicanparts.com/uploa...1325721159.jpg
Brown747 02-07-2012 04:30 PM
Engine installed
Took advantage of the spring like weather we've been having in the northwest and installed the engine today. C/V joints and brakes to go through but getting closer.
Thor
http://forums.pelicanparts.com/uploa...1328660653.jpg
http://forums.pelicanparts.com/uploa...1328660686.jpg
http://forums.pelicanparts.com/uploa...1328660722.jpg
Before
http://forums.pelicanparts.com/uploa...1328660748.jpg
After
http://forums.pelicanparts.com/uploa...1328660786.jpg
Reiver 02-07-2012 05:33 PM
Man, I need a pressure washer.
combatic 02-07-2012 06:45 PM
Nice job! I am going to have to try your mineral spirits trick! I literally used a dental pick on my 40+ year old 901 to get at the nooks and crannies and nearly wrecked my back.
Brown747 02-07-2012 06:52 PM
Thanks Bryan... Look forward to meeting up when we get our cars on the road.
Thor
jrolstin 02-08-2012 01:17 AM
Excellent work. I am in the process of doing the same to my car but I am only halfway through my engine drop because I have been working so much lately and have been busy with school...
Interested in hearing on how the reseal went and if you were able to rid of all of your leaks. Did you replace any seals in the tranny? My trans is leaking for sure and motor as well from 160 places probably.
Brown747 02-08-2012 04:14 AM
Jonathon,
Still some work to be done before I start it up to see if my work was effective. As far as the tranny , I replaced the front cover gasket and shift shaft seal. Differential shaft seals, input shaft seal and o-ring. Stay tuned for results.
Thor
will hung 02-08-2012 05:22 AM
Beautiful work. Out of curiosity, how did you manage to get your fan to look like that? I love it. I'm dropping my engine to do some gearbox work and will be going through a similar set of projects.
Brown747 02-08-2012 05:49 AM
The fan, shroud, and intakes were glass bead blasted then protected with a coat of rubbed on ACF-50.
Lear Chemical Research Corporation
al lkosmal 02-08-2012 05:50 AM
Thor,
Looking very good. Nice attention to detail and detailing...................get out the movie camera for the 1st fire up!.............
regards,
al
will hung 02-08-2012 11:58 AM
Exactly what I needed to know. Thank you very much.
Your project and attention to detail is an inspiration.
QldChef 02-13-2012 02:47 PM
Well done Thor......i'm feeling very inspired!
macssc911 02-23-2012 05:14 PM
Brown First I want to say great job, you have inspired me to do close to the same on my 82 SC all going well , I do have question on the sound insulation. I am going to install this weekend, did you use a glue If so what was your process, was thinking a contact cement or glue Thanks Mac
al lkosmal 02-23-2012 05:20 PM
fire it up....youtube!!!
al
efhughes3 02-23-2012 05:23 PM
Use 3m high temp spray adhesive. Mine's held for about 8 years now.
jhummel68 02-23-2012 06:08 PM
al
I second the thought of recording the start up. If I ever have to drop my motor, I think I'll be giving you a call. I enjoyed reading through this thread. Keep us updated.
