First time engine drop
Engine is coming out for a broken head stud, SSI's , reseal, de-smogging, and a growing list of "while its out" items. Followed Wayne's book and all was straight forward.
Thor ![]() ![]() ![]()
1978 SC coupe #1834 |
76 911S Targa
It was that clean BEFORE you took it out?
...good on you, man...i know you enjoyed that sierra nevada!!!
Today a little clean up before going after the studs. Mineral spirit rub down then blasted off with the pressure washer. Exhaust was removed without breaking any studs. Heated the nuts to red hot with an oxy/acetylene torch and they came right off.
Congrats. Keeps us posted. Just curious, what kind of jack is that?
1985 Triple Black Cabriolet-ROW**Sold** 2008 Cayman S Guards Red/Black 2007 Audi A4 2.0T Red/Black |
darnellsgarage
Wow, did you get it that clean with just mineral spirits and a power washer?
don |
Nice work Thor! I need to get over there and learn from you.
Todd Dry 1982 911SC |
Member 911 Anonymous
Hot Damn that is a Great Clean Up, I am humbled!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Lookin really good!
Progress report
I've had some time to work on the car lately so here is a little update. Engine was stripped down to the studs and all lower Dilivars replaced with steel. Broken head stud defeated Cylinders are back on and I'm waiting for the baffles to come back from powder coating. Cleanup of the engine bay and new sound pad installed. Bilsteins have been sent off for rebuild. I met up with Ed M , aka Ivangene and had him put in a set of his Derlin bushings in my shift coupler, Thanks Ed!
Christmas came early :D Derlin Shift Coupler ala Ed M Picked up a 2 out Monty to go with my SSi's. I'm not sure I want to go this route yet but it sure is a thing of beauty. The PO had cut the outlets off and had them rotated up for his early car so I'll have to cut them and rotate them to clear the SC bumper. I'm hoping I can get this thing back together before the rains set in! Cheers, Thor ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
1978 SC coupe #1834 Last edited by Brown747; 10-16-2011 at 07:51 AM.. |
How did you get the shroud like that?
Matt. 83 911SC 85.5 944 NA - Sold |
Shroud Krylon overhaul
Matt,
I degreased with mineral spirits. Wet sanded with 220 grit. Final rub down with acetone then applied a couple coats of Krylon gray primer. Color coat is Krylon Banner Red applied in several light coats until I had good coverage and then one good coat to blend it all in. HTH Thor ![]() ![]()
1978 SC coupe #1834 Last edited by Brown747; 09-24-2011 at 11:40 AM.. |
Looks great. Will the paint hold up to the engine temps?
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
it does look awesome but I'd be concerned about the heat too...giving off fumes etc. I'd use engine primer and engine paint.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Not going to sweat it... If it doesn't hold up I'll redo it when I drop it for carburetors
915 cleanup
Spent most of today with a toothbrush, mineral spirits, and the pressure washer.
I'm running out of things to clean up. Must be time to start putting things back together. TJ ![]() ![]() ![]()
Nice work!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
