I would rather be driving
jpnovak's Avatar
Sounds like you have solved all of the installation issues. Having going through this process a number of times let me offer the most important advance.
DO NOT relay entirely on a map or tuning file you got on the internet. Every car, even with the same engine, is a little different. YOU MUST tune your particular engine.
Tony makes a fantastic kit and provides nice base maps but you now need to set the VE table. Properly done this will eliminate the bucking and poor low-rpm response.
Invest in a wide-band oxygen sensor and integrate it with your MS unit. This will give you quantitative feedback on what the engine is doing. Then systematically set the fuel trim on your map. Take your time and you will be rewarded with a highly responsive engine that makes great power and gets improved mileage.
Old 08-05-2011, 06:12 AM
Milo2361's Avatar
boom. fuel pressure regulator was holding pressure at 22psi. adjusted it to 36 like tony's fuel pressure gauge manual says and its freaking awesome now . solid idle, going to go drive it and report back
1998.5 Ram 2500 Cummins
Old 08-05-2011, 11:54 AM
Happiest when Tinkering
gsmith660's Avatar
Good glad to hear would still suggest a wide band O2 for the tuning portion and your in like flynt. Wheres Bayard NE?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-05-2011, 12:03 PM
Milo2361's Avatar
far western nebraska, about 40 miles from the Wyoming border. you may have heard of scottsbluff, NE. about 20 miles from there. its the closest "big" town - 14,000 people. cheyenne, WY is about an hour and a half, Denver, CO is about 3 hours 45 min away.
went and drove it - no sputtering or stalling, a little better throttle response than with the CIS, but still feels the same in power - no real change there. Tuning is definitely necessary to increase the power i suppose. after warming it up, it hunts just a little bit at idle. say 50rpm maybe. that might be caused by a tiny vac. leak correct?
Old 08-05-2011, 12:34 PM
gsmith660's Avatar
One cause of hunting is if you look at your VE table in megatune and while you idle it bounces between bins in the table and if those bins have different values then you will have a change in idle.
Old 08-05-2011, 01:16 PM
Milo2361's Avatar
hmm.. its not surging enough to change bins. it stays in the same one the whole time - i can just hear it going up and down.. very slightly.
Old 08-05-2011, 01:18 PM
gsmith660's Avatar
See folks were right it runs pretty good right out of the box Tony made a great kit. Enjoy LOL glad to see it work out for you welcome to the slippery slope just give yourself more time to complete the project next time one thing you learn with these cars is sometimes the best laid plans.................
Old 08-05-2011, 02:15 PM
Milo2361's Avatar
oh the slippery slope has been going for a while... next is a ducktail, SSI's and an M&K Gt3 style... once all that is in place then i might take it to a dyno shop for a pro tune...
Old 08-05-2011, 02:19 PM
R.I.P.
drmatera's Avatar
Are you using Megatune or TunerStudio?
Old 08-05-2011, 04:32 PM
Milo2361's Avatar
I'm on megatune. I really am not sure how to use all the features, but i did read, understand, and change the autotune config settings - now i just have to go drive to see what it does for me. any advice would be appreciated or if anyone who has a BITZ kit is in the denver area that would help too
Old 08-05-2011, 05:36 PM
Scott R's Avatar
I'm in Denver, I ran the kit for two years. But I think I read you're 3.5 hours from here...
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-05-2011, 05:55 PM
Milo2361's Avatar
yes i am. i did figure out why my car didn't feel "faster". one of the electrical connections the kit says to unplug and tape off fell down under the throttle mechanism. blocking my throttle to about 30% instead of getting all the way. man when i floor it now it seriously has more power. not even tuned yet. It turned out great
however, as my car warms up my idle comes up from about 800 when cold to around 950-1000 when warm. a very tiny surge happens every now and then? but it runs extremely smooth through all other rpm ranges
Old 08-05-2011, 08:03 PM
Milo2361's Avatar
Trond, i just watched a youtube video of your EFI. the guy tuning your car didnt by chance give you the MSQ file he created did he? I'd love to try it out and see what happens!
Old 08-05-2011, 09:15 PM
never ending projects
niner11's Avatar
I've been playing around with megasquirt II on a turbo datsun for about 4 years and the newer version of tuner studio is amazing. It incorporates a program called megalogger I think that will do a great job of auto tuning a base map with a wideband. The same guy writes both programs. Good luck!
Old 08-06-2011, 09:16 AM
R.I.P.
drmatera's Avatar
Actually its called VE Analyze live. Using feedback from your wide band it will "tune" your VE to almost perfection by just driving around. But before you do any "tuning" create a new tune so if you end up screwing it all up you can just go back to the Tbitz tune and all is good.
Old 08-06-2011, 12:45 PM
Registered speed offender
78SCRSMAN's Avatar
Great write up! I'll be doing the same some day on a 3.0 w/gt3 cams and 2 in 2 out exhaust. I was going to go with a home brew ITB setup but now leaning toward CIS base for my first go round. Should be fun.
Thanks for sharing.
It sure would be nice to have a tuning tables thread.
Old 08-06-2011, 01:42 PM
R.I.P.
drmatera's Avatar
I agree, with more and more guys using the MegaSquirt EFI it would be great if there was a thread just for posting .msq's not to mention there is more to tuning than just watching a/f
Old 08-06-2011, 02:44 PM
Milo2361's Avatar
that would be really helpful. (tuning tables thread)
i'll probably get the wide band sensor in a couple of months. i tuned my idle VE settings to near perfection on the narrow already tho. it runs very smooth at idle now. Im really hoping to spring the cash on a set of SSI's and an m&k gt3 style soon too. thats when that VE analyze live thing would come in handy real well
Old 08-06-2011, 04:36 PM
Milo2361's Avatar
UPDATE:
Drove down to Lincoln to finish up college. ~400 mile trip. I got 28.5 MPG at ~79mph for most of the trip with a very slightly modified original map (change was to smooth the idle)--- no cruise control either, and a few good stomps on the gas coming off the ramps onto the interstate and some good gas pedal action working over some jackass tailgaters.
thats up from ~24mpg or so. literally 20% better mileage
Old 08-13-2011, 07:04 PM
Been There Done That
So then I guess you would say its worth the money then?
Old 08-13-2011, 07:10 PM
