A/C issues on 1979 SC - Shutting off after couple seconds
My A/C is turning off after about 15-20 seconds of running. It seems to start getting cold or cool, I can fix that issue or any leak but it cutting out I am not even sure where to start. Once you turn it to off for a second or two it will do it all over again. Anyone have any issues like this or even an idea of where to start?
I had a problem like that once, on a trip to Charleston in the summertime. A call back to my local Porsche wrench led me to the switch on the lower console. Turns out the contacts were burned. I managed to file them off enough using my wife's emery board (for nails) and got it fixed enough to get through the trip. It's a real pain getting that switch out, seems almost to be glued in. Anyway, I replaced it with new one from our host after we got home and no problem since. Apparently that system sends all the voltage through that switch.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 08-10-2011 at 07:15 PM.. |
El Duderino
+1 on the switch
Gerry,
thanks for excellent pictures, looks like the full current to the clutch may be going through this switch.. maybe more reason to have the diode installed at the clutch as mentioned on another thread -h |
Mine's feeling not so "fluid" on it's sweep (rotation)...time to pull and have a look....
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
