				voltage regulator how do you know
			Hi All,
				How do you know what alternator you have so that you can buy the right voltage regulator. I have a 72 T 2.4. I think I have a 55 amp alternator which should make it a motorola, I think. I need to purchase a voltage regulator. The one I have is a black plastic covered version. I think I need to buy a bosch regulatory but need feed back to know. Any thoughts to make sure I purchase the right one.
	_____________________ Mark 911 T 1972 Black almost done!  |
				Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
 Good luck, Gerry
	1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases."  |
 You need the Bosch (mechanical) regulator to match the OEM alternator. This sits on the left side panel in the engine compartment.
	Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com  |
				voltage regulator
			Thanks Steve, for comfirming this.
					I probably will need a rebuild of the alternator as well so I thought of replacing both alterntor and regulatory at the same time. I wanted to keep this combination. I've read on Pelican that it is better to stay with separate regulatory/alternator combination rather than going to the more modern self contained regulatory in alternator combination.
