Formerly known as Syzygy
Early this summer, I had the suspension refurbished with some upgrades. Larger torsion bars were installed as well as new struts with raised spindles. In the process of corner balancing and alignment, it was lowered about 1/4 inch; it used to be 25/24.5 inches. That wasn't my intent and I suppose I wasn't clear enough in my desires. Regardless of the height, the bump steer issue has all but disappeared.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
MBruns for President
I'm at 24 and 24.5 - really about as low as I want to go.
Bump steer kit - ![]() with my track wheels ![]() at speed ![]()
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
One step ahead of you. I also wasn't presistant enough with my alignment shop. They reduced my front camber significantly resulting in slight rubbing at the left front with my 205/55-16's on 7's. So I trimmed my fenders and used the slimmest dolly I could find to hammer what was left of my lip upward.
Once it is as low as it can go. Mounts 15 inch rims with low profile tires for the track and now you are talking.
Chris 73 911 E |
Jeremy reagarding the bump steer kit - you talking rack spacers or tie rod kit or both? Like I said I am at 24.5 and 24.25 and my tie rods are reaching for the moon, with the rack spacer.
Jeff Last edited by NoLift911; 08-10-2011 at 10:57 AM.. |
Rack spacer on mine - that's all - even with sebring (known for lots o bumps) not bad at all
Any idea what your tie rods look like? Angle wise?
Jeff |
El Duderino
I just got the car back from the shop. It was not level so I had it adjusted and the alignment re-done. I went about as low as you can go with no rubbing. The rear was about 1/2" lower and we had to take it back up. It's currently set at 24-7/8"rear and 25-1/8"front. Running 16x6s front and 16x7s in the rear. Suspension is stock with Bilstein shocks. I have been wondering if I need the bump steer kit, but honestly haven't spent any time on it as I've been working on so many other things on the car.
Here's a pic:
At what point do drop spindle struts make sense?
I can't imagine being able to go lower than Jeremy with my car. Thoughts?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Raised spindles for me was to correct suspension geometry and eliminate bump steer. I suppose if your steering is kinda wonky (bump steer or tie rods level or angled up) it might be time.
My 79 with 17 inch wheels sits at 26.5 front 25 rear.
Pretty much all ER track race with 23 / 31 Torsion bars and Tarret sways. 225/15 in front with 235/15 in rear on 7s and 8s. Fenders were rolled before paint.
However. If you do raise the spindles you will require a bump steer kit as the steering arm/knuckle gets raised as well. If you have objectionable bump steer, this part is a no brainer. |
Any idea how much?
Elephant shows these strut spindle heights: +19mm / 15 inch wheels +30mm / 16 inch wheels +40mm / 17 inch wheels Custom height available I'm trying to understand why wheel size matters if you go with the appropriate size tire to keep the tire diameter the same.
Max Sluiter
If you raise the spindle the ball joint almost rubs on the inner wheel rim so the wheel size dictates how far you can raise them.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
Here is standard height. If you raise the spindle the A-arm stays where it is but the wheel moves up.
![]() Front Suspension Geometry_ 012 by Max_911_fahrer, on Flickr
You canīt get low enough..
1974 911 cab. RoW 3.2 with carrera3 CIS, Bosch HKZ ignition, SSI, 915- 7:31, curb weight 1115Kg, 231Hp. BMW 530dA touring |
