spark plug sockets
anyone reccomend a good.....magnetic.....socket, for 911 plugs. looked at hazet. ?? thanx j.
Old 08-10-2011, 08:50 AM
the stock tool in the tool kit that comes with the car works very well
Old 08-10-2011, 08:53 AM
gruppe f
mikehinton's Avatar
+1. In fact, the stock tool is the only one I have found that will get all of the plugs out. The mechanic I use for major stuff showed me a cool Snap-On tool that he uses that basically operates on the same principle as the stock tool.
Mike Hinton
'06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine,
'74 914 1.8 Marathon Blue, '64 356C Aubergine
Old 08-10-2011, 10:05 AM
brads911sc's Avatar
Buy a used stock tool. There really is NO reason to reinvent the wheel on this one... Nothing works better.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 08-10-2011, 10:25 AM
muck-raker
kidrock's Avatar
I picked up a used stock plug tool from a Pelican for a fair price about 15K miles ago. I used it for the first time last week. I'll never use anything else ever again. Worth every penny.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-10-2011, 10:58 AM
Just bought A snap-on extra long socket today thinging it might work good and it does on the #2 #3 #5 #4 cylinders but #1 and #6 cylinders it does not. So I will look for a factory tool. Hope this helps. Craig.
Old 08-10-2011, 06:58 PM
gecc's Avatar
I've used this for the past 30 years. Hazet 2505-2
Old 08-10-2011, 07:19 PM
závodník 'X'
intakexhaust's Avatar
The early 6 and 7 series BMW's used to come with a nice tool kit that was built into the trunk lid. Tools were by Hazet and the spark plug tool was sort of like the 2505-2 (as posted by gecc). It has an internal spring steel that grips the spark plug insulator for plug lift.
Old 08-10-2011, 07:34 PM
m110's Avatar
Snap on magnetic socket, weld it to a 3 inch extension, use with a stubby ratchet. I have also used the Hazet one above which works fine.
1988 Carrera Coupe
Old 08-11-2011, 08:18 AM
Yes it does, but is the rubber sleeve inside replaceable? Part number or equivalent? Mines worn and doesn't grip as well anymore.
Sherwood
Old 08-11-2011, 09:34 AM
gruppe f
mikehinton's Avatar
The main thing to look for in the tool is a thin-walled socket. Most spark plug sockets have thick walls, which prevent them from accessing the plug. The factory tool has thin walls, as did the Snap-On tool that my mechanic uses. The other important feature of the factory tool is the "swivel" function, which allows the tool to negotiate the confines of the cylinder head.
Mike Hinton
Old 08-11-2011, 11:23 AM
AutoBahned
RWebb's Avatar
or use a locking 3" extension
BTW - there a few older threads on this very topic and they have pics!
Old 08-11-2011, 11:56 AM
the carrera didnt come w/ a stock tool kit. ideas where i can locate one? j.
Old 08-19-2011, 08:25 AM
Chain fence eating turbo
Timely thread.
I just had our machinist take off 0.020" off my Craftsmen 13/16" spark plug socket.
There is 0.050" of meat at the thinnest part, so you can machine 0.020" off and it clears every head. Cylinder #6 and #1 were my tightest.
Also, I took a round file and wore away at the rubber insert too, to make sure I can retrieve the socket with just the friction of the detent ball of the extension.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-19-2011, 08:34 AM
