Brorag
Brorag's Avatar
field test results
I was taking the wee beastie back to the ragtop guy to do final adjust, and hit a pothole. The car bottomed out and the wheels struck the surface. I could hear/feel the strike. The car remained under control. Exam'd the wheel and environs and found no damage. Paint scraped off wheel contract area ~1/16th ". No bent noth'n.
It works.
Old 08-25-2011, 09:28 AM
Eugene at Pelican Parts's Avatar
How loud was the sound compared to scraping metal? I was never fond of the attention drawn from scraping driveways--especially when it's not your own.
It works.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 08-25-2011, 10:45 AM
Brorag
Brorag's Avatar
not loud
just a dulcet bump, no scraping--it rolled. I was the only one that noticed it. It took me over the obstacle and that was it. Why don't you get Wayne to start making them? All I want is a small percentage
Old 08-25-2011, 03:56 PM
Canyon Runner
70SC's Avatar
Nice shopping cart
Old 08-25-2011, 04:07 PM
Brorag
Brorag's Avatar
Shopping cart? No, much better............
did you see the pic where we used it for a firewood cart?
Old 08-26-2011, 05:48 AM
kinein's Avatar
Send a message via Yahoo to kinein
wheel
yep i knew a guy who had one on his 83 slant nose the casters where a hard plastic wheel.....i thought it was a brillant idea for a lowered 911 for driveways and what not....
Has anyone had any experience using something like these to prevent your lowered porsche from bottoming out?
Old 08-26-2011, 06:16 AM
You have put a lot of work into your car, looking good now.
Old 08-26-2011, 07:21 AM
Champagne on Beer Budget
HelmetHead's Avatar
How about something like this using the front mounted spare tire
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-26-2011, 07:58 AM
Just to review. There's no difference between bottoming out on a rigid caster wheel and bottoming out on the underside of the chassis. If a caster wheel hits something, like a bump in the road, it's the same impact on the chassis, despite the fact it can also roll after the initial impact.
Sherwood
Old 08-26-2011, 09:09 PM
Max Sluiter
Flieger's Avatar
Point being? Skid plate would have the same impact as well.
Old 08-26-2011, 09:15 PM
Understood. However, discussion seemed to veer toward protecting against bottoming out by adding stuff to the underside. All that does is decrease ground clearance and increase risk of bottoming out.
Slowly negotiating a driveway is something else. A skid plate is fine except for the noise it creates.
S
Old 08-26-2011, 10:40 PM
Max Sluiter
Flieger's Avatar
Yeah, I would probably just try to change lanes around the potholes but then I don't live there so it might not be possible. Then I would try to go slower.
Variable ride height like the KW kit for late model cars would be nice.
For driveways, the wheels look like a great solution. No scraping noise (or at least not as much) and no hard impacts.
Old 08-27-2011, 10:44 AM
Brorag
Brorag's Avatar
thanks, Kach..........
Roadtrip!!!!!!!!!!!!!!
Helmethead, sounds like another project!
Remember, most pioneers have more a$$ than the injuns got teeth.....................
Old 08-27-2011, 11:37 AM
Max Sluiter
Flieger's Avatar
? more info please
Old 08-27-2011, 11:38 AM
Brorag
Brorag's Avatar
getting itichy
Don't know, Flieger...............time to get the wee beastie on the road.
JD
Old 08-27-2011, 11:48 AM
Cool, rotate in one direction in "D", rotate in the other direction using "R".
I wonder how many beers it took to come up with that idea. I cannot argue with something that works, and that works.
Edit: Would this last long on the street?
http://www.vividracing.com/blog/announcing-new-products-specials-and-info/apr-carbon-fiber-splitter-for-mitsubishi-evo-x-released/
Old 08-27-2011, 12:49 PM
Brorag
Brorag's Avatar
It might be too low...........................
This is better than watching the soaps..........or having a bad case of athletes feet............it just keeps on going....................
All is well till I take a right curve uphill at speed, then the spoiler in front of the drivers wheel scrapes.
Back to the front end, and up it about 1"--use weights to account for load.
Old 09-12-2011, 09:42 AM
Brorag
Brorag's Avatar
Just what is the best ride height?
After a suspension rebuild and alignment, I found that when driving in the mountains, the part of the spoiler in front of the drivers front tire scrapes occasionally when engaging a sharp uphill corner turning either left of right.
Maybe I've got this thing too low?
No, no more wheels.................
I started searching and came across this thread
Code:
fender height measured through wheel center
	rear	front
	25	25
	24	24.5
	24.25	24.5
	24.25	24.75
	24	24.5
	25	25.25
	25	25.5
	25	24.5
	25	24.5
	25	25.5
	25	24.6
	24.25	24
	24	24.5
	24	24.75
	24.25	23
	23	25.5
	25	25.5
total	416	420.35
avg	24.471	24.726
in real #'s	24.5	24.75
my car	24	25.3
Gotta go off and think.................
Ideas?
Old 09-14-2011, 11:22 AM
wayner's Avatar
I just stop and pick up a hitchhiker and have them sit on the whale tail for particularly bumpy sections of road. :-)
SOLD - 914 wide body hot rod
Old 09-14-2011, 12:25 PM
j911brick's Avatar
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives...................................... .................
Blazing Saddles...
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 09-15-2011, 02:17 PM
