idle ajustment on 3.2
did a search for idle adjust on 3.2... no luck would like to adust idle lower
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Do you have a Bentley? Good luck, Gerry ![]() ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Or try this method, compliments of 911Chips.com
Please take time to read the instruction...Idle setting is outlined after chip installation, or in your case, without chip installation. (See page 3) http://911chips.com/C1INSTR.pdf HTH, ![]()
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Diss Member
We need to be clear about the idle speed adjustment listed in the above 2 posts. This will not reduce the idle below the speed set in the programming of the DME. The reason for this procedure is to get the system adjusted so that the main butterfly is adjusted so it can be correctly compensated for by the idle air control valve.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
certainly: the "mid point"!!
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Ooopppss
OK, the idle switch adjustment screw....the one that says "Don't touch this." How serious is that statement?
Installed the SW chip, went to adjust idle speed down (jumped up to 1800 RPM when warm) but idle speed adjustment only had less than one turn in it before completely closed. I could feel 1/4" on the adjustment screw and thought, I can get more out of that, and I did....got it to idle at 950 RPM before running into this thread. I can get both settings back to "close" and get it to my mechanics to fix my doing OR DO I NOT EVEN START IT? In short, am I harming the engine if I run it now? Thanks!
Thanks, Chris 1980 Targa, 3.2 upgrade |
The idle switch screw will be a physical adjustment so that the idle switch IS engaged when the throttle is not depressed. This is what tell the DME it's at idle...it's functionality can be checked with an ohmeter.
I'd say your mix needs a baseline check.... BEST Doyle
Doyle,
Agreed, now that I've moved, back and forth several times, both adjusters, I need to have them reset by someone other than me.....my concern, at this point, would I do any damage to the motor by driving it?
Thread Tools | |
Rate This Thread | |
