restoring turn signal housings- a few questions
I am restoring some 70-73 front turn signal housings. Today I used aircraft paint stripper to remove the old flaking finish. I'm now down to bare pot metal. I'm either going to use Rustoleum cold galvanizing spray or maybe a chrome metal spray. My question is do I use the same type of primer regardless of which top coat ? I was thinking of using a self-etching primer. Is this the right primer ? Any other tips ?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Recreational User
I used Rustoleum primer followed by Rustoleum chrome, and it came out great!
Any chance for a before/after photo? I'd like to see how it turns out.
Von Whitley Los Alamos, NM |
Do you remember which primer you used ? They make several.
Recreational User
Fleabit peanut monkey
I would use the Rustoleum Professional line. Then you can get the matching primer.
I do not see a chrome but I see an aluminum. I like the stuff. Always flows nice and it is tough. http://www.thepaintstore.com/Rust_Oleum_Professional_High_Performance_Enamel_p/752483.htm Do not use etch primer on pot metal. Paint Job - Mustangsandmore Forum Archive Excerpt: Self etching primers contain phosphoric acid, a good thing, but not for pot metal pieces like headlight buckets |
Bob K thanks for the post. I am familiar with the Rustoleum professional series of spray paints I've used them on other projects. Always had good results. I'll have to check out their aluminum spray vs. a chrome spray. Not really sure how reflective the surface really has to be ? I bought these housings for cheap but all of the interior finish was a wreck
. One housing will also need some JB Weld repair but that's easy enough to do. I'll try to snap a pic of the raw housings and then a finished one to show the difference.
I restored mine in a similar way to what is being recommended here. The chrome paint works very well. The lights are clear and bright.
I used the chrome paint on my headlights and difference in brightness compared to my old faded ones was significant. I think you'll be fine with it.
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Recreational User
Here's what I used -> RustOleum.com
It came out very bright. Not quite chrome, but much more reflective than silver. |
Ed 1973.5 T |
