rfuerst911sc's Avatar
restoring turn signal housings- a few questions
I am restoring some 70-73 front turn signal housings. Today I used aircraft paint stripper to remove the old flaking finish. I'm now down to bare pot metal. I'm either going to use Rustoleum cold galvanizing spray or maybe a chrome metal spray. My question is do I use the same type of primer regardless of which top coat ? I was thinking of using a self-etching primer. Is this the right primer ? Any other tips ?
Old 09-04-2011, 08:03 AM
Recreational User
porschenut's Avatar
I used Rustoleum primer followed by Rustoleum chrome, and it came out great!
Old 09-04-2011, 10:57 AM
Any chance for a before/after photo? I'd like to see how it turns out.
Von Whitley
Los Alamos, NM
Old 09-04-2011, 11:07 AM
Do you remember which primer you used ? They make several.
Old 09-04-2011, 03:47 PM
I'm past the before as they are already stripped. Just picture crappy looking metal with flaking white crap/chrome looking coating coming off.
Old 09-04-2011, 03:50 PM
Recreational User
porschenut's Avatar
Sorry, I don't. But I would imagine any metal primer would work fine. I just grabbed the one that was on my shelf.
Old 09-04-2011, 05:31 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I would use the Rustoleum Professional line. Then you can get the matching primer.
I do not see a chrome but I see an aluminum.
I like the stuff. Always flows nice and it is tough.
http://www.thepaintstore.com/Rust_Oleum_Professional_High_Performance_Enamel_p/752483.htm
Do not use etch primer on pot metal.
Paint Job - Mustangsandmore Forum Archive
Excerpt: Self etching primers contain phosphoric acid, a good thing, but not for pot metal pieces like headlight buckets
Old 09-04-2011, 06:03 PM
Bob K thanks for the post. I am familiar with the Rustoleum professional series of spray paints I've used them on other projects. Always had good results. I'll have to check out their aluminum spray vs. a chrome spray. Not really sure how reflective the surface really has to be ? I bought these housings for cheap but all of the interior finish was a wreck . One housing will also need some JB Weld repair but that's easy enough to do. I'll try to snap a pic of the raw housings and then a finished one to show the difference.
Old 09-05-2011, 03:00 AM
D911SC's Avatar
I restored mine in a similar way to what is being recommended here. The chrome paint works very well. The lights are clear and bright.
I used the chrome paint on my headlights and difference in brightness compared to my old faded ones was significant. I think you'll be fine with it.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 09-05-2011, 05:56 AM
Recreational User
porschenut's Avatar
Here's what I used -> RustOleum.com
It came out very bright. Not quite chrome, but much more reflective than silver.
Old 09-05-2011, 06:18 AM
E Sully's Avatar
I used non etching Rustoleum primer
Refinishing turn signal housings
Blinker housing rebuild
Ed
1973.5 T
Old 09-05-2011, 06:57 AM
