Experts -install rearview mirror
Please let me know the best way to remove orig
rear view mirror from windshield and install on new windshield.
Frank
Old 09-06-2011, 03:20 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Frank
Frank,
There have been several good post on this subject.
Suggest you do a search-rear view mirror.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-06-2011, 03:26 PM
mnewport's Avatar
Heat the puck from the other side of the glass. I used a hot air gun for mine. The mirror will pop off.
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik
Old 09-06-2011, 06:10 PM
Tom '74 911's Avatar
Frank,
I just installed a new windshield on my car and had to do this too. My mirror was stuck to the old windshield w/double sided tape/pad stuff, not the typical glue an installer would use. I was able to get it off using a long razor blade knife tool w/out issue. I decided to order the sticky tape for the new install too as I didn't want to mount it too permanently and cause issues for the next 'new' windshield. . . If your mirror is installed w/glue, I can't help! Sorry!
here's the PN & link:
901-731-133-20-M260
Porsche 911 Interior Trim - Page 2
Good luck,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-06-2011, 06:17 PM
2Utes's Avatar
To remove most adhesives, heat and patience are your primary tools. using a small plastic wedge (like a tile spacing wedge) can help to keep a tension force on the adhesive while you heat it to weaken the bond strength.
To locate the new mirror puck, measure and mark on the outside of the windshield with a sharpie or other removable marking.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 09-06-2011, 07:07 PM
rearview mirror install
Thanks for all the insight
Frank
Old 09-07-2011, 09:41 AM
Frank,
Don't make the same mistake I made; I installed the button upside down and now will have to remove it carefully! So make sure you mark the top because it has a slight wedge shape to lock the mirror into.
-Rutager
Rutager West
Old 09-07-2011, 03:02 PM
Heat it up " grab a guitar g string with gloves
Off in 10 seconds . Have a grab assistant
It can scuff the dash. No good
Old 09-07-2011, 07:02 PM
