GaryR's Avatar
Send a message via ICQ to GaryR
I just use a long bar with a handle shoved into my lug bolts to hold the wheel while she is on the lift, works great.
Gary R.
Old 09-11-2011, 02:15 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by schumicat View Post
I think you will be less likely to strip the heads if you don't use a long extension on the CV bolts...
Not really if you are perfectly align. I lift the car to just above my waist line then I able to put a good pressure on the bit before torquing it.
Who Will Live... Will See
Old 09-11-2011, 02:25 PM
<insert witty title here>
Christien's Avatar
Originally Posted by arbita1 View Post
I know that they are disconnected from the transmission. I was looking more for tips on technique. What's the easiest was to get them off?
I do it with the wheels off, from underneath the car, with a crowbar (or similar) in between two wheel studs to hold the axle still. Piece of cake.
Originally Posted by wichitaguy57 View Post
When I did my drop, we didn't so much as lower the engine from the maximum height, but raised the rear end while keeping the engine as low to the ground as possible.
What did you jack under, when raising the car, with the engine disconnected?
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-11-2011, 03:03 PM
efhughes3's Avatar
Originally Posted by timmy2 View Post
Everything else is disconnected and I'm ready to drop engine and tranny, car is just sitting on my lift. Now I'm "patiently" waiting for the jack adapter to arrive "by Wednesday" according to tracking supplied by our host...
I could drop it onto my ATV/motorcycle lift, but I ordered the right tool so I'm gonna use it!
Not sure if it is the "right tool" in as much as it is "a tool". In my mind, the adapter on a floor jack takes a big back seat to using the ATV jack. The ATV jack is a lot more stable.
You lift the entire car, then lower the front to raise the rear. You still need approx 25-26" under the t-bars at the rear, so that the ass is ~39" AFF.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-11-2011, 05:26 PM
arbita1's Avatar
Are the front wheels on the ground when you do this or is the front still on jack stands? I think my front spoiler would prevent me from having the wheels on the ground if I was to lift the rear up that high.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-11-2011, 05:30 PM
Christien's Avatar
Ed, your process involves a lift, correct? I'm asking because I have my engine out currently, but my car on the ground (put the wheels back on). I had it up on jack stands, then lowered the engine out like I always do, but I didn't have one of the jack stands in properly and the car started to lean really badly (scary as hell, first time in hundreds of times lifting the car that's ever happened). I jammed some temporary jack wherever I could, slapped the wheels back on and lowered the car down. Problem is, now I have no idea how I'm going to get the car back up
Old 09-11-2011, 05:34 PM
efhughes3's Avatar
Unless you have some custom splitter, you won't have a problem. Yes, the wheels are on the ground, and on my car never created an issue with a factory spoiler.
What I just described is done when you DON'T have a lift. You are on jackstands, and is the safest way to drop an engine, IMO. You are working with everything level, then when the motor is free and ready to drop, you slowly drop the front to raise the rear off the engine. This way you aren't way up in the air with the motor, especially if one uses a normal floor jack. I've done several drops this way. Nowadays, I use the lift.
I don't understand why you can't raise your car back up?
Ed Hughes
2015 981 Cayman GTS
Old 09-11-2011, 05:44 PM
Christien's Avatar
I usually lift the rear of the car by the engine, under the sump plate. That's the way I've always done it, and I'm not sure where else to lift from, if the engine's out.
Old 09-11-2011, 06:00 PM
efhughes3's Avatar
You should have spots on each side for jack pads.
Ed Hughes
2015 981 Cayman GTS
Old 09-11-2011, 06:22 PM
ROW '78 911 Targa
timmy2's Avatar
[QUOTE=efhughes3;6248984]Not sure if it is the "right tool" in as much as it is "a tool". In my mind, the adapter on a floor jack takes a big back seat to using the ATV jack. The ATV jack is a lot more stable.
When "the Tool" arrives I will assess. If I feel the need I will fab something to make it work with the ATV/MC lift and have the best of both worlds. Stability and the ability to adjust the angle of the powertrain without shimming with wood blocks or other dangerous for pinch point methods. I've managed to work on 500KV electrical for 25 years without an injury. I'd hate to have something like a motor drop on me!
Old 09-11-2011, 07:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Well, I did two drops in 2 weeks. ( don't ask :-( )
I purchased a 1500 lb Motorcycle Jack at HF, with a piece of 1"X12"X36". I dropped both Trans & Engine.
I raised her on to 6 Ton Jack Stands until wheels were off the ground.
Then placed the Motorcycle Jack with piece of Wood under the center point of the Engine and Trans, about a foot where I normally raise the car. Raised the engine until the engine mounts came up about an inch.
Disconnected/Removed as Bentley/101 described.
After initial separation, I raised the chassis at the wheels ( engage E Brake ) one side at a time, gradually for safety, until high enough for my heater blower to clear my rear valance.
Grabbed the engine mount cross member and polled back, Voila, Engine Out
INSTALL, I lowered the chassis to the engine, raised the engine about 6"s+/- and slipped right in.
All this by myself, took her for a spin today, could not take the silly grin off my face.
NOTE: Keep organized, use shoes boxes to keep thing in order or use sandwich bags. The first time I did not do this and kicked my pile of nuts/bolts, What a nightmare
Jim
PM me if you have any questions.
As far as the CV bolts, I removed the wheel and used a piece of 1.5"X 48" OD wooden dowl and jammed it on the wheel studs. Used the same dowl to rotate as I loosened each bolt.
Just make sure the allen tool is seated all the way in before wrenching on it, YOU DO NOT WANT strip it. It is easier to loosen from the top or side position, there is zero room trying to get to the bolts when they are in the lower (6 o'clock position )
I was lucky I only stripped on on 2nd install. I ordered 6 back ups and CV gaskets from our Host. If a pre 85.5 915 it is only 30 ft lb torque. Like you wheels, torque in a Star Fashion.
Hope this helps!
'85 Carrera Targa
PCA/POC
Old 09-11-2011, 07:48 PM
arbita1's Avatar
Just curious, why did you lift at the wheels and not the rear jack pad location?
Picking up a 20" long 3/8" extension bar from Sears on the way home from work for the CV bolts. And also borrowing the special Pelican oil line wrench from a fellow Pelican who lives close by. I'll hopefully have the engine out soon.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-12-2011, 10:42 AM
Originally Posted by Rodsrsr View Post
If you have a second person it's a little easier. They can be in the car on & off the parking brake while you rotate the axle shafts and undo the cv bolts underneath the car. Also, don't forget to undo the shift coupler.
Why not just stick a screwdriver in the vents of the brake rotor to prevent it from turning?
Rick
88 Cab
Old 09-12-2011, 11:07 AM
Ambitious Outsider
sabeo.m's Avatar
This is what my car looked like when I dropped my engine. I did have a little bit of a clearance problem. It worked out as soon as I removed the valence.
1988 3.2 Cab
2005 997.1 C2S
Old 09-12-2011, 01:32 PM
AutoBahned
RWebb's Avatar
This is what my car looked like when I dropped my engine. I did have a little bit of a problem.
Old 09-12-2011, 02:15 PM
Ambitious Outsider
sabeo.m's Avatar
Anything else that goes wrong with your car seems minimal compared to this-dang! Hope no buddy was hurt.
Old 09-12-2011, 02:34 PM
AutoBahned
RWebb's Avatar
that was just a joke - also an admonition to be careful ---> note the too small fire extinguisher
Old 09-12-2011, 03:03 PM
Christien's Avatar
I don't trust them - there's some rust in there, and I wouldn't feel comfortable sticking jack pads in there.
Old 09-12-2011, 03:08 PM
koenig's Avatar
Nobody has mentioned removing the bumper. A few nuts and some electrical connections and the whole thing is off. Gives you many much-wanted inches of clearance. Here's my drop with nothing lifting the front, jack stands and wood lifting the rear torsion bar to about 25 inches. ATV jack lowering the engine.
Paul
82 911SC ...living the obsession
Old 09-12-2011, 03:40 PM
koenig's Avatar
Just realized you already have your bumper off. Good luck with the drop and be careful.
Paul
Old 09-12-2011, 03:43 PM
