A/C hoses?
I have read many times on this forum that Porsche made their hoses leak refrigerant on purpose over time. That was the design. My question is why? What could be the reason? Why do American cars like a Mustang GT go 10 years or more blowing ice cold? With no added refrigerant? Same with my Wifes old Dodge Caravan?
Old 09-19-2011, 07:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Job Security for the Porsche Mechanics?
I agree it seems odd. Maybe the AC gurus will chime in .
Hell, I replaced my driverside to modern barrier hose at a local industrial hose shop using the OEM fitment, suppose not to leak. So far so good but I still have the OEM on the passenger side, I need to refill once a year.
'85 Carrera Targa
PCA/POC
Old 09-19-2011, 09:11 PM
kuehl's Avatar
No. Porsche did not "by design", design, make or install hoses that leak on purpose. The only things that truly leak on purpose are wiki-leaks and the our federal budget.
The issue with 911, 912 and 930 models is having nearly 40 feet of old fashion refrigerant hose whereas a front engine car of the same era may have about 10 feet. Old fashion refrigerant hose leaks so many parts per million per linear feet at a given pressure and temperature. It's a known fact that with these models you may have had to 'top off' the system from time to time. So, what you need is a set of refrigerant hoses that leak less (they have an additional liner inside) which we call 'barrier hoses'.
I disagree on "Why do American cars like a Mustang GT go 10 years or more blowing ice cold? With no added refrigerant? Same with my Wifes old Dodge Caravan?" because I can remember quite a few front engine cars of the 1960-1970 era we had to add refrigerant to at times.
Old 09-20-2011, 11:46 AM
Do they really have 40 ft of hose?
Old 09-20-2011, 01:19 PM
Yes they do.. I've worked with automotive A/C since the late '60s, and as Griff stated it was not uncommon to 'top off' R-12 systems every couple of years.. R-134a systems seem to 'loose' less refrigerant than the R-12 systems.. I recently had to add a little refrigerant to my Harley pick up (R-134a- 10yrs old).. In the 'old' days an oil stripe on the inside hood of an automobile from the compressor seal was considered normal..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 09-20-2011, 01:50 PM
