A/C Diagnose - Temp switch vs Fan switch
Searched a lot but need a referee call - Sorry for basic question. 88 Carrera
My A/C compressor clutch engages as soon as Fan switch is rotated CW to first detent even with A/C Temperature switch fully CCW (rotated left) My mechanic felt that compressor clutch should not come on if Temp switch is fully CCW - therefore leaving me free to use Fan switch for airflow without A/C. So I was headed towards troubleshooting Temp switch based on what I understood to be a few posts indicating that operation had been restored after cleaning contacts. Preparing for the work with Bently manual, it describes the function of the system as: Temp Control Knob - fully left for low cooling - fully right for full cooling. Fan Switch - Position 1 no cooling / blower off. Positions 2 to 4 A/C on, increasing blower. This leads me to believe my system is working as designed - except that it might be be working the A/C compressor/system too hard at lowest Temp setting. So does this mean that A/C blower fan CANNOT be used for cockpit ventilation/cooling WITHOUT A/C compressor working? I would like to get air from center/side registers without always having to use A/C. Thank you for your confirmation. |
On my 85 the compressor always kicks on as soon as the fan is turned on. If the temp switch is all the way down the temp will cool the sensor in the evaporator fairly quickly. The compressor will start to cycle fairly soon. It will still cycle on and off occasionally no matter what the outside temp.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
The temperature switch only functions to turn the compressor on/off based on the temperature it senses in the evaporator. So unless the ambient temperature is pretty low, even at the lowest setting on the temp switch the compressor should kick on.
Also, the system does not bring any outside air into the cabin. Its a closed loop. Air flows from the cabin through the opening under the passenger floorboard, then through the evaporator and back into the cabin. So the AC blower fan can't be used for ventilation or cooling even without the compressor working.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
As per the previous post, compressor activation is dependent on temp switch position, and the signal from the evaporator throught the capillary tube to the temp switch. For minimum compressor "on" time, the temp switch should be fully CCW, and the fan on position 4. You could re-wire the two green wires in back of the temp switch to activate the compressor per your requirement. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 09-27-2011 at 03:38 PM.. |
Thanks to all AGAIN. What a great host and members.
You saved me from trying to "fix" something that wouldn't change. Now to review posts regarding the A/C Temp switch capilary tube to see if it might be causing the compressor to stay on all of the time. I sense mine is staying on all of the time. |
Also, you might want to clean the switch contacts. If you remove the temp switch, be VERY CAREFUL of the capilary tube. pm me as needed.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 09-27-2011 at 05:12 PM.. |
