MSD 6AL-2 ignition upgrade
I was wondering if any members out there have installed the MSD 6AL-2 ignition system on their 3.0L CIS engines? How much did it improve performance overall?....worth it? I have an '80SC with BAE Turbo and was wondering if I should perform the upgrade? Would it be at all possible to send me a PDF of the installation manual?.....much appreciated!
Alex |
THere are other threads on this subject, one only a few days ago. There will be no improvement in performance, unless of course your existing unit is defective. You may notice, I did, a slightly smoother motor below 3k. I think their website has the instructions in downloadable form.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Registered Porsche Driver
FWIW I've had bad luck with the 6AL-2. went thru two that both crapped out at rather inconvenient times. went back to a 6AL, no issues.
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
I had an MSD in my 2002 that failed and cost me a race weekend. Not a fan.
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Thank you gentlemen! Interesting...sounds like it's 50/50 with regards to the MSD upgrade. My engine idles just fine, however, my problem is at around 4000RPM+....lot's of hesitation and then surging when I come on boost. I thought having a programable system would allow me to tweak the advance/retard. How about the Perma-tune upgrade?...any comments would be greatly appreciated!
Alex |
Note that the MSD 6 AL 2 isn't programmable. It does have a rev limit switch. Perma-tune won't do anything but fix a not-properly-functioning stock unit. Not sure your problem has much to do with the CD unit.
Note that the MSD 6 AL 2 isn't programmable. It does have a rev limit switch. Perma-tune won't do anything but fix a not-properly-functioning stock unit. I know nothing of turbos but think I'd look elsewhere.
Burn the fire.
Instead of the "MSD" Brand Multi-Spark Discharge Unit, go with the Mallory HyFire VI-A version. Digital instead of analog and I've yet to have a box (out of the dozens I have installed) fail.
Aside from that note... You will notice the improvement at idle and across the whole RPM range if your CIS system is in good/great shape. BUT! The improvement is best felt when upgrading the coil, plugs and wires as well.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
the MSD is a very good unit. there are too many out there using them for it not to be. as for an upgrade from a bosch, it is not. but when my bosch crapped out, the MSD was a much cheaper alternative. daveE, anything can break or go bad.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Yep, 14 months, 9 race weekends(35 hours tops), mounted in the cockpit with isolators. I'm still waiting for the CDI in my '78 SC to fail.
it will, the capacitor in your is bosch are very old.
Thread Tools | |
Rate This Thread | |
