Scotts Independant used to mount a very large condensor under the seat area with no fans. I've see several cars with this kit around here and the a/c works VERY well. I think it was about 48 in wide and 18 long. Amazingly it survives quite well there as long as you do no rallying.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Senior Member
RS,
This condensor was marketed under the Performance Aire brand. I used to have one and finally sold it this spring to put a parallel flow condensor in.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
A/c
balleta- did you get the trunk A/C installed. I have the same interest. Let me know how it turned out.
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
However, you need the knee room or toe room, much easier to do in a 356 or 914. Naturally, and then you still need the drier, compressor, comp mount, barrier hoses, condenser(s), clamps, wire harness, etc. |
Knee space is not interrupted since the unit is in the trunk not inside the car. That was about the route of the 964s blower sytem.
Sent from my GT-I9100 using Tapatalk 2
![]() 911 C2 Turbo Look ![]() Harley Fat Boy ![]() Jeep TJ Sporttrac Adrenalin![]() 911 SC(sold) Sporttrac(sold)
"'all-in-one" units simply bolt under the dash, hence 'knee room',
you'll never fit a 964/993 entire box in the 911 trunk... easily |
slotmeister
All in one units "usually" are mounted under dash but in this application it goes in the trunk. Then outputs goes to the vents via conducts. Recirculation is provided the same way, one hose at each side of the blowers goes to holes from the cabin. Cabin air flow is improved and with an under the front fender condenser, barrier hoses, etc. the package is complete.
Oh, I have seen 'in the trunk' evap boxes with blowers; self contained.
Even worked on a few, some were unique and another I recall simply did not do the job. You can build one too if you want to. They are not an upgrade to a stock system. You can purchase a used stock evap box system and air tubes and fittings, and just drop it in the smugglers box alike a factory set up. In either case of a 'in the trunk unit' vs dropping in a factory style unit, you need wiring, controls and vents. If you have an earlier narrow body car you don't have much room for vents in the dash other than one above the radio. And for factory ac units through 1985 you simply did not have enough vents... Tri-Kuehl Vents Years ago we designed a system for cars that did not have air. Spent 3 months on trying to perfect the 'perfect' vent arrangement. In the end the original Behr Knee Pad system was the best design, in terms of vent location, number of necessary vents and control location. The cost to duplicate that unit (molds, minimum number of shots off the molds, etc) is not as affordable as simply finding a good used Behr knee pad vent and fixing it up, and locating a good used pre 86 Behr evap box and dropping it in the Smugglers box well and cutting the necessary holes. There was a company that marketed an 'alike' Behr knee pad panel but the quality and design is not as good as a 'good old original'. |
I already have a Behr knee pad vent unit. Do you know how compares the "original" smugglers box unit with improved fan motor and a universal under dash unit in terms of CFMs?
Use an anemometer
Blasphemy & Sacrilege to the promoters of 911 serpentine technology condenser heat exchangers LoL Joe I thought you posted several times here you went with Griffiths serpentine condensers! Hmm has he seen the light??? |
balleta
before you go hacking up any of the body on a 911, you need to think very carefully how it is going to de-value the 911 Also understand that the OEM evaporator with a few smugglers box and evaporator tips and tricks done to it, i.e. availible here in the 911 Pelican tech threads etc; can be made to work pretty good with only a little TLC. Remember That the most imporant problem on an early model 911 is its condensers for making a cold a/c, maybe this will help you think a bit differently ICE COLD A/C 30's F |
Banned
