oil level sending unit
When I purchased my old 73 911 a couple of years ago and finally got it running, (almost a couple of years later), the oil level gauge stayed in the red. The oil level when the engine is warm is fine, and the oil pressure is about where it should be. I've disconnected the gauge to avoid having to watch the needle barely move.
Like most of us, I would like everything to work when and where it should, so I put it on my to do list. checked the wiring, and thought I found a bad ground on the sending unit side, cleaned and tightened it up, but there seems to be a problem elsewhere.
Is it fairly common for the sending unit to go bad? My fuel gauge unit had to be replaced because of corrosion, but oil sending units?
Thanks for any input, gary
Old 09-28-2011, 03:20 PM
Diss Member
Quicksilver's Avatar
I've had 2 of them fail. It seems (from my very small sample group) that the replacements are rather cheesily made.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-28-2011, 03:41 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Gary
Try a search on "oil level sender" and you will get a few post that take you the removal, cleaning and re-install process step by step.
Who Will Live... Will See
Old 09-28-2011, 04:16 PM
FPB111's Avatar
Could be "normal" for cold oil that is slow to make it back to the scavage pump. What level shows on the dip stick when cold and the gauge shows in the red red?
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 09-28-2011, 04:56 PM
Troy
my oil level guage always reads quite a bit lower until engine is completely warmed up, then reads correct
Old 09-28-2011, 05:17 PM
JJ 911SC's Avatar
That is normal.
If correct, the guage should in sync with your dipstick when you do your oil check at Operating Temperature, on a Flat Surface after Idling for a Minute.
Old 09-28-2011, 07:15 PM
I haven't yet let the engine warm up after my faulty ground repair. I'll re-attach the gauge and see what happens after a few miles.
Thanks for the heads up, g
Old 09-28-2011, 07:29 PM
I had a ground problem that caused several issues ncluding similiar to this issue. Once I fixed my grounds everything behaved well.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 09-28-2011, 09:45 PM
Mitch Leland's Avatar
Oil Temp Gauge...
You really need to have your engine temps get warm before you get an accurate read on the oil level gauge. If it's a cold day then the reading will be lower since your oil temp is going to be lower. If it's a really hot day the oil expands and the level will read higher. That is why you don't want to overfill your sump. But over all my gauge is dead on with the dip stick...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 09-28-2011, 09:55 PM
Send a message via Skype™ to Porboynz
When you remove the oil level sense wire the guage will peg itself on full, so if yours is not budging off the low stop then it suggests a hard earth on the sense wire. Try pulling the sense wire off the rear of the guage then measure to earth. Maybe you can hook the float with some wire and move it from empty to full and observe the resistance.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 09-28-2011, 11:11 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OLSU Fix
Here you go: Oil Level Sending Unit: How to Service / Repair / Maintain
'85 Carrera Targa
PCA/POC
Old 09-29-2011, 12:02 AM
