VIDEO How to test a Speedometer
Hi Everyone,
So after nearly a year of intermittent speedometer operation, I decided to get to the bottom of it. It's been very unclear whether the issue lies with the speedometer itself, or the sensor. On a hour long drive, the speedometer will cut in and out several times. So, I decided to pull it from the car and bench test it. Well, more like kitchen table test it. That way, I could run it for a couple of hours and see if it every cuts out.
Here is a video showing how I did the test, along with a schematic. If you end up doing this same test, PLEASE be careful and beware of the voltages at play, it is very possible to blow something up.
I've heard that the sensor in the transmission sends 8 pulses per wheel rotation. My 225/55/16 tires have an overall diameter of 25.7 inches, which means 1 rotation covers 80.68 inches of ground. At 60 MPH, I'm covering 63,360 inches (5,280 x 12) per minute, or 1,056 inches per second. 1,056 / 80.68 = about 13 wheel rotations per second, or 104 pulses per second
1985 BMW 325e - 2 Door
1982 Porsche 911 SC Euro Spec
1965 Land Rover Series IIa Restoration Project
1999 Land Rover Discovery II
2002 Suzuki SV650 Naked Bike
Old 09-28-2011, 08:08 PM
Max Sluiter
Flieger's Avatar
Gee, I thought this was going to have a video of an Autobahn run.
Old 09-28-2011, 09:00 PM
Max Sluiter
Flieger's Avatar
Old 09-28-2011, 09:03 PM
I like it !
Which generator app did you use ?
How did you choose the transistor ? How did you set the volume on the iPad ?
Finally, I can't read the component names on the drawing.
-Guillaume
Old 09-29-2011, 06:40 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
you've just convinced us all to send you OUR speedos if we have a problem.
Old 09-29-2011, 07:38 PM
jdbunda's Avatar
Very nice - so did you find the problem?
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 09-29-2011, 09:05 PM
Well, I now know that the speedometer is not the problem. I've tested it for hours and it has not failed.
Time to look at the sensor.
tabasco,
The app is called Tone Gen Pro, it was 99 cents.
I just used an NPN Transistor that could handle 12 volts. It's a 2N3904.
The writing on the speedometer says "viewed from rear" for pin reference
The two wires on the bottom are labeled "Audio Hot (Tip or Ring)" and "Audio Ground (Sleeve)"
Old 09-29-2011, 09:45 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
interesting, this couldn't have come at a better time. I'm having problems with my speedo now and have been wracking my brain on how to test it. Thanks!
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 09-29-2011, 11:18 PM
jrumiano's Avatar
Good post! If you don't have an iPAD, a function generator is the way to go.
Something like this.
2 MHz Function Generator / Frequency Counter SFG-1002 | eBay
Good luck.
John
Old 09-30-2011, 07:16 AM
ewave's Avatar
That's not quite true. What you know is that your speedometer is reliable on a bench in an office with a stable voltage power supply.
1) You refer to the power supply as unregulated, but in your application where the current draw variation is almost zero, the output will be quite well regulated probably to within 50 mv. You want to at least be able to run the speedo from 10V to about 16V for testing purposes. (Hook an oscilloscope up to the supply voltage.)
2) Your speedo is subjected to considerable vibration in the car. If you are looking for an intermittent electrical problem, you need to simulate vibration of some kind. In situation like this I usually tap the device under test with the handle of a screwdriver. This works really well to find lose flaky connections.
3) In the car the speedo is also subjected to a considerable temperature variation. To simulate this a hair dryer works quite well. For cold testing the freezer is my choice.
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 10-01-2011, 11:49 AM
dshepp806's Avatar
BINGO! There's still more work to do.....
You may want ID the adjustment for calibration, for your viewers,..as most people are in need of THAT!
Thanks for the time and effort.
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-01-2011, 02:26 PM
