Grand Am/IMSA Data Guy
Porsche84's Avatar
Get a pick or something pointed, insert it between the threads and the remaining metal and pry it toward the center. Time consuming but necessary. You should be able to run a tap in the hole without cutting much metal so you do not cross thread or remove metal from the threads in the aluminum.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 10-28-2011, 04:25 AM
don't use a cleanup tap until you get the remaining threads out. a small punch ground to a sharp point and a small hammer to get it started under the edge. pry it outward and grab with small needlenose pliers. some pull out like a helicoil. some break and you have to go in again for the rest. patience.
206 637 4071
Old 10-28-2011, 05:21 AM
Attached is the link of a post (with pics) that I posted some time ago regarding drilling out an exhaust stud on my 944. It's a different situation and engine but the process is similar.
Broken Exhaust Stud - Fixed :) Photos of My Repair
Vern
Old 10-28-2011, 05:42 AM
arbita1's Avatar
Ok. That's what I thought, but I was afraid to start doing that without checking first.
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-28-2011, 06:02 AM
arbita1's Avatar
Thanks all!
Matt.
83 911SC
85.5 944 NA - Sold
Old 10-29-2011, 09:31 AM
