Grand Am/IMSA Data Guy
Get a pick or something pointed, insert it between the threads and the remaining metal and pry it toward the center. Time consuming but necessary. You should be able to run a tap in the hole without cutting much metal so you do not cross thread or remove metal from the threads in the aluminum.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
don't use a cleanup tap until you get the remaining threads out. a small punch ground to a sharp point and a small hammer to get it started under the edge. pry it outward and grab with small needlenose pliers. some pull out like a helicoil. some break and you have to go in again for the rest. patience.
Attached is the link of a post (with pics) that I posted some time ago regarding drilling out an exhaust stud on my 944. It's a different situation and engine but the process is similar.
Broken Exhaust Stud - Fixed :) Photos of My Repair Vern |
Matt. 83 911SC 85.5 944 NA - Sold |
Thanks all!
