cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Unhappy Bad CV joint ?
1973 911 E
My car makes a "clunka, clunka" noise from the rear end when coasting (engine off clutch in or out). Can feel it as well, so not a subtle problem.
I assume it's a CV joint. Jacked up the rear end and both wheels spin freely with no noise or other abnormality. Pretty sure it's on the left side. Both half shafts are tight when I pull on them against the bearing and move freely in and out (toward the wheel and engine).
Is there a better way to confirm it's a CV joint? Are CV joints repairable?
Normally I would find the problem and replace the CV joint. However, I replaced the half shafts with CV joints several years ago, because the boots kept tearing, and the CV joints that came installed on the half shafts are at least half an inch thicker then the stock ones so replacing them might be difficult as I don't know whats actually on there except that they fit and had worked perfectly for at last 5 years. Finding the correct size CV bolts to go with these was a bit of a pain and I don't remember where I bought them from.
4 bolt CV's with the half moons and a shuffle pin.
Any advice is greatly appreciated.
Chris
73 911 E
Old 10-07-2011, 01:07 PM
Mo money = mo parts
Could be a bearing too. They often whine, but if can clunk. If your CV's are relatively new, I would check on the bearing first.
Jack the car up, grab the tire and 12 and 6, check for play. 3 and 9 check for play. Spin the wheel slowly by hand and feel for a gritty or rough motion during rotation. It might not feel like much.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-07-2011, 01:27 PM
cmcfaul's Avatar
Figured it out. Easiest fix ever. Apparently I did not tighten down the lug nuts I am embarassed to admit.
Oh well back in action :-)
Chris
Old 10-09-2011, 09:04 AM
Grady Clay's Avatar
Chris,
Well ... that is a solution and satisfying/unsatisfying conclusion.
Admissions will help the uninitiated. Thank you.
Here is the definitive thread on this subject:
reconstructing-constant-velocity-cv-joints
While very long, it is worth studying end-to-end.
Here is a Search Result with more valuable links:
Pelican Parts Technical BBS - Search Results
One on my (yet unfulfilled) projects is to combine all these very important posts into one thread.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-09-2011, 10:05 AM
AutoBahned
RWebb's Avatar
Grady - you need some interns. Still involved with high schools, community colleges?
Old 10-09-2011, 11:05 AM
Grady Clay's Avatar
Yes, I'm open to volunteers.
I'm also a good cook. Teens take note.
Best,
Grady
Old 10-09-2011, 11:50 AM
