Exotic Vehicles are here
Hey Guys!
My Front S-Caliper has a plate witch connects brake line to the caliper and it attached with 4 bolts =see between arrows= to the caliper with the possible O-Ring GASKET inside. My question is what is the part number for this O-Ring GASKET? The ATE Rebuild Kit 901-351-998-00-M4 DOES NOT include it. Also, If someone has pic of the S-Caliper with open lid, please post. http://www.pelicanparts.com/more_info/Customer_Comment_Images/1318344136-1900.jpg Thank you. -Youri
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com |
Max Sluiter
I would ask the brake guru, Eric Shea
Brake Restoration Service He can help you with parts questions, not just restored calipers.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
+1 on Eric Shea.
+ one more for Eric. He's your guy.
I also have a disassembled S caliper @ home if you need a photo still send me a PM and I'll post one up here. K
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
-Y
Here you go Youri.
I've got the back plate off. You can see the 4 bolts that hold the plate on the caliper body, and the interior of the caliper. You should note the channel on the caliper body with the O-ring that seals the back plate and keeps fluid from running out. The back plate also has the knock-back post on it. Sorry for the late reply, I was off @ RRIV. Cheers
I bought a bagful of O ring seals made in EPDM for this application - send me a PM with an address and I will post you a couple.
Stoddard has the O ring for the end cap, SIC-351-999-00, fits 1969-1973 911S.
R/Dave |
Thank you guys so much!!!!
You are the best!!! Do you know by the chance that is the torque for those bolts? Also, do you have any advice how to clean S-Caliper Aluminum surface? It looks like I need some sort of chemical solution... Thank you in advance. ![]() -y
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com Last edited by 1-ev.com; 10-17-2011 at 07:43 AM.. |
Bump
PMB Performance
I doubt you're still looking but for others that might be...
Those should be 12.9 fasteners and spec is anywhere from 13-15lbft. I always go 15 on an X patern. The seal is a 52x3 in EPDM Check the lip on that cover as they often have corrosion or chunks missing from DAPO's cramming a screwdriver in there to get the cover off.
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Thank you.. :-)
PMB Performance
Sorry... 51x3
| Tags |
| s-caliper front rebuild |
