LinkBack | Thread Tools | Rate Thread |
Chain fence eating turbo
Doesn't the cylinder head temp sensor give a signal to the temperature gauge?
If your CHT sensor is failing or failed, wouldn't the temp gauge show false readings?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, depending on mood ![]() |
Platinum Member
Do you mean the temperature gauge on the dash? That reads oil temp. Different sender.
Temp gauge is for oil. CHT reports back to the ECU if I am not mistaken.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
No, the temp gauge just shows oil temperature. CHT sends it's signal to the dme for mixture control.
Ed 1973.5 T |
Ah, I always assumed that was head temp.
Makes, sense as the head probably heats up rather quickly and the oil lags behind.
Thread Tools | |
Rate This Thread | |
