Choosing appropriate distributor for RS spec engine
Hello,
I am building a 2.7 RS spec engine and need a distributor. The engine is built on a 7R case with genuine RS heads and piston/cylinders. It will be fed by an entire MFI system from a 2.2S (including pump). I have the possibility to buy a 001 or a 008 distrbutor. What is the difference between the 2 and which one should I take? Thanks Mathieu |
RETIRED
The 12 point single is pricey. I've thought that the belt driven 3.6 belt dual dizzy would work. Lots cheaper.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Rs dizzy
Talk to Aaron Burnham over on the engine building forum. He builds distributors and rebuilt mine for my 2.7 rs spec motor.
World of difference! His avatar is burn bros I think Kevin |
Banned
JB racing has a single plug, six pin, fully adjustable distributor with a magnetic pick up. I bought mine through Steve at Rennsport. Hooks up directly to the MSD, no points either.
Very clean unit. Last edited by dipso; 10-22-2011 at 06:03 PM.. |
JB Racing is the best.
Banned
That's it. Here's what it looks like in the car.
It's just a distributor, but the thing is made of billet aluminum, feels like a machine and is fully adjustable for whatever advance you want.
![]() BTW, what's the 001 and 008? Sherwood |
Thanks everyone, I have more info on the 2 distributors:
First a 0231 184 001 which seems to have been used on 2.7s from 74 to 77 The other is a 269 008 which was used on late 73' T models. If anyone knows the curve advance for these 2 distributors that would be very helpful! Thanks |
Sherwood |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ron,
Thanks for the chart. Just to be clear, the 231 159 002 distributor shown (2 liter S engines) provides approx. 22º of centrifugal advance (RM page L-39), about the same advance as the 2.7l Carrera distributor (RM page 9.3 - 2/6). Later T, E and S spec distributors produce approx. 30-34º of centrifugal advance (page 9.3 - 2/1) Either of the above specs don't include the recommended static timing settings before or after TDC. (Note: ATDC static timing affects total timing advance when measuring BTDC). Also be aware that the factory charts present distributor timing specs either in crankshaft rotation degrees or distributor rotation degrees (1/2 crank speed); potentially confusing to read and compare the various timing charts. Sherwood |
