Clock loses time overnight
Can't seem to locate a problem. If it would just quit it would be different. Basically, it works for a couple of days, or weeks, but I'll come out one morning (my daily commuter SC) and the clock will have stopped around 01:00 - 03:00. Doesn't quit during a regular 8-hour day but when shut down it seems to quit about 8.5 - 10 hours later. Start-up and it's working fine and never loses time when the car's running. Thing is, if the gear-train were bad it should stop during the day around the same time (13:00 - 15:00).
The battery's fine and I haven't suffered any electrical issues.
Anyone else experience this? I would just replace it (the previous owner replaced it around 5,000 miles ago) but I'm not certain it's the clock and not some electrical idiosyncrasy.
Old 10-26-2011, 05:31 PM
Banned but not out, yet..
RSBob's Avatar
do a search on clock repair. there is a guy here who does repairs for cheap
Old 10-26-2011, 08:32 PM
steely's Avatar
That is odd. Dumb idea - try setting it up 12 hours to see if it dies in the PM after your morning commute? Maybe something to do with the gears.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-26-2011, 08:33 PM
That's the problem, it stops at around 01:30 - 03:30 but it doesn't stop at 1:30 - 3:30 PM. I have spun it around but it shouldn't matter, being a 12-hour clock. So, it quits at 1:30 - 3:30 AM but not PM.
If it quit at both, it would obviously be the clock's gear train and an obvious problem.
Old 10-27-2011, 08:13 AM
gtc gtc is offline
abides.
gtc's Avatar
Possibly a temperature issue. Sometimes they slow down/stop when it's cold. Old, gummed up grease is the culprit.
Old 10-27-2011, 08:29 AM
12-hour face clock.......
rackjack,
I'm no clock expert so I'm just throwing some thought. The face of the clock is a 12-hour dial, but inside might be a 24-hour gear. Just thinking loud. Someone with actual experience in servicing these clocks should have a better suggestion.
Tony
Old 10-27-2011, 09:43 AM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
I've heard about this, you've traveled back in time what you need is a flux capacitor and some plutonium to generate 1.21 gigawatts...
'88 Carrera
Old 10-27-2011, 09:55 AM
But doesn't this apply only to the Delorean automobile?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 10-27-2011, 10:57 AM
I test drove a DeLorean with an automatic and I'm not sure it could reach the requisite 88 MPH.
Old 10-27-2011, 03:31 PM
My clock does the very same thing since I have owned the car. Works great on a trip. Then several hours it just stops after the car is parked. . I was told to put in a new capacitor and a resistor and that should fix the problem. Mine keeps perfect time on a trip. My Wife told me that if it works on a trip then what is the problem? Nick
Old 10-27-2011, 03:45 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Many times the issue is only two capacitors.
Here's a link:
Fixed my clock
And here's the capacitors:
Hope this helps.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-27-2011, 03:54 PM
Easy explanation.. Someone's ghost lives in your car.
Old 10-27-2011, 05:35 PM
Make Bruins Great Again
Por_sha911's Avatar
Being gummed up when its cold sounds plausible. Also, is your battery and charging system 100%? Maybe it is stopping due to marginally lower voltage from sitting?
Joe
Old 10-27-2011, 06:51 PM
My thanks to all of you for your responses and suggestions. The charge system is in great shape and my Fluke shows just under 14v for the battery in the morning, prior to startup.
I'm going to dismantle it and check the lubrication but I am thinking that 86 911 Targa's suggestion is the most viable explanation and fix.
After is solder in some new caps, I'll post the results. The previous owner replaced the clock around the time of the Capacitor Plague. I recall numerous motherboards, and other electronics, of that period that had bulging, leaking caps.
rackjack
Old 10-28-2011, 10:14 AM
steely's Avatar
would be very interested in a follow-up. It's odd to think that the caps would involve a problem with such a weird time-constant, but let us know.
Dan
Venetian Blue
Old 10-28-2011, 02:53 PM
efhughes3's Avatar
It's the temperature. Mine's done that for 10 years, during the cooler months. Seems like over 60F, it's fine. One of the quirks of Ruby, that I've learned to know and love.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-28-2011, 03:11 PM
Mine just started doing the same thing since we hit cooler days in the low 40's to 30's degree temps. Runs fine while im driving and stops over night.
Old 12-15-2011, 02:59 AM
It took only 49 years!
mclmk8d's Avatar
Does your chewing gum lose its flavor on the bedpost overnight also?
(sorry, first thing that popped into my mind when I saw the word overnight...took me back to my childhood)
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 12-15-2011, 08:05 AM
Thank you all for your input.
I wound up using the Radio Shack 272-1028, the 100 microfarad 35 Volt caps.
This appears to have cured the problem. The most difficult aspect was removing the bezel without destroying it. I misunderstood the posted tech article instructions. The edge of the bezel is crimped over and you have to pry it up a bit at a time and then crimp it back once reinstalled. The instructions left me with the impression that it would sort of pop-off with sufficient encouragement. However, you have to actually bend/un-crimp
Once off, it was an easy fix. I used a small block of hardwood and a small pair of Channel-Locks to re-crimp it. The pros typically use bezel rolling tools but building one isn't worth it unless you're doing this on a regular basis.
Old 02-06-2012, 05:42 PM
Additional follow-up;
so, after 6 weeks the clock has functioned flawlessly. Until this weekend. Parked early Friday afternoon and by Monday morning it lost about 17 minutes. (Keep in mind that it used to lose 4 or 5 hours a night on colder/sub 60 degree nights.)
I'm going to keep track of it and make sure it's not a fluke. I did reset the white tell-tale and maybe the set knob had engaged the movement and I didn't notice.
However, it has functioned flawlessly for 6 weeks down to about 38 degrees (F) in the garage without stopping.
Old 03-19-2012, 01:59 PM
