Renovating calipers, do I need to change the lines too?
I'm currently in the process of renovating my front calipers and got the tip that the flexible brake lines can sometimes deteriorate and need replacing. But once the wheels and rotors where off (the rotors are either machined or replaced) and I could take a good look at the lines it seemed as they had at some point been replaced with braided ones (?). I have no history on the car so no idea how old they are. Should I get some new ones or is it likely that these are ok?
![]() ![]() Cheers, Björn
1980, 911 SC. Ex-US car in Sweden since June 2010. Insta: @911scowner |
The one in your pic looks yucky and rusty... I'd replace them. they are cheap, so while you're at it, etc... but be careful and use flare end wrenches, or you'll be busting out the vise grips..
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
definitely replace them. all four of them.
SOLD: '87 Carrera |
Evil Genius
While you're down there, that's a awful loose and sloppy looking worn out sway bar bushing too.......
Life is a big ocean to swim in. Wag more, bark less.
Björn,
Absolutely replace those brake hoses. First, the SS aftermarket hoses are (in my experience) far less quality and durability than OE or OEM Ate hoses. You will find my technical explanations here on Pelican along with many other’s. There is little controversy about this issue. Your first order of business should be to re-install OE or OEM rubber hoses. These hoses should be replaced every few years. How often is dependent on climate, use and how you value your life. I replace mine bi-annually for my street cars (annually for the race car & hot rod). These are not expensive parts and should be part of your regular maintenance program. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Member 911 Anonymous
+1, replace, hell you are in there anyways. Rust = Bad
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Spiderman
Go ahead and start shooting the PB Blaster/Kroil whatever now. Mine came loose fine this past weekend but didn't look as bad as yours. I stayed with OEM rubber hose, I figure they were good enough for the first 24 years, why should I second guess this detail. Good luck.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Ok, I hear ya, will do!
Thanks for replying! /b
