front end question
I have a 82 sc
the front end feels poopie
when i go on a road that is the least bit bumpy
it feels like i have no co control of the steering
Old 11-01-2011, 01:57 PM
ivangene's Avatar
start with tires, condition, tread, ages, pressure
then wheel bearings...snug, no play, not tight....
brakes, FREE
tie rod ends check
ball joints check
steering linkage check
anti sway bars, ON and mounted
then shocks, front bushings,
alignment (maybe sooner on this one)
Ed M
86' Coupe
Old 11-01-2011, 02:04 PM
Flat Six
Flat Six's Avatar
+1, and ride height
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 11-01-2011, 02:16 PM
French Import
zippy_gg's Avatar
Originally Posted by Flat Six View Post
+1, and ride height
Bump steer kit needed?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-01-2011, 04:59 PM
I'm not an expert but it sounds like either worn tie rods or alignment. I'd bet on the tie rods. I just replaced mine and upgraded to the turbo's. It made a big difference.
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 11-01-2011, 06:20 PM
redridge's Avatar
+1 on tie rods.... Upgrade to turbo version. If lowered you need the bump steer kit.
Old 11-01-2011, 06:25 PM
Max Sluiter
Flieger's Avatar
Do not do the bump steer kit yet. Only after all else has been sorted and only if car has been lowered significantly and the handling is not to your liking.
Old 11-01-2011, 06:28 PM
what if i just get the stock tie rod ends
Old 11-02-2011, 05:43 PM
Max Sluiter
Flieger's Avatar
Just get the turbo tie rods. There is no reason not to.
Old 11-02-2011, 05:45 PM
I highly recommend the turbo's. I lowered mine too and did not have to get the bump steer kit.
i will check the for sale
thanks
Old 11-02-2011, 06:10 PM
Porchcar guy's Avatar
I assume you have gotten your car back from the shop after the dropped part down the engine hole. How is it running after the repairs and what needed to be done to fix it ?
+1 on all the above mentioned things...look at them in order and verify what your needs are.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 11-02-2011, 08:07 PM
replaced the wheel bearing and it did the trick
thanks everyone
Old 11-04-2011, 06:31 AM
