How do trailing arms differ?
I am restoring a 74, and I am updating many parts. How do trailing arms differ from 74-89 or are they all the same.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
In 78 the connection point for the sway bar drop link changed from a ball post attached to the TA (how the post is attached seems to be a bit of a mystery), to a standard bolt fastener. This only matters if you want to use an OEM style sway bar because most others appear to mount the drop link at the spring plate.
btw, let me know if you are looking for a set of 74-77 style Trailing Arms.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Are they all aluminum?
Max Sluiter
Post 74 all are Aluminum.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Home of the Whopper
I thought the '74 was a one year only and the sway bar mount changed in '75?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
AutoBahned
not sure when that mount changed
the Al arms are lighter, stiffer, and IIRC stronger than the old steel ones at some point, P AG put bigger rear wheel bearings into the Al arms, so the wt. went back up a bit |
If anyone is looking: I've got a nice pair of aluminum arms off of a 1976, complete with new Elephant Racing monballs installed. Send a PM if interested.
74 to 89 are all Al.
There is no reason for you to update if you have good 74 Al arms. If for some reason you do use a later year than 74, make sure you keep the stub axles in the arms as they are 69-74, having 4 bolts and 2 pins to match to the CV joint.
Tru6 Restoration & Design |
There is some more info here about the sway bar mount for 74-77 vs. 78+ trailing arms:
1974-1977 Sway bar Question. '77S to SC Drop Link Conversion Questions... 911sc Rear Suspension & Swaybar And many more links if you search for " trailing arm drop link ball"
great everyone, thank you for the time. This place continues to amaze me.
