CDN Redneck
Capt J.D.'s Avatar
Speed/Reference Sensor Bracket on 3.2
Had to remove the actual bracket to replace the two sensors.. (corrosion).
Upon removal, the bracket itself seems to be missing one tube. (The part #930-101-089-01 shows two tubes.)
Are there in fact two tubes or one; for the sensors to fit into? The Reference Sensor position has a tube and the Speed Sensor position does not on my bracket.
TIA
Old 11-11-2011, 06:53 PM
abit off center
cgarr's Avatar
Mine only had one tube too.
______________________
Craig
G2Performance
Old 11-11-2011, 06:55 PM
Northern Motorhead
wildcat077's Avatar
Just had my engine out recently and my sensors only had one tube ... 89 3.2 engine
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-11-2011, 06:58 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Ditto,
Just be very careful putting the new ones on, DO NOT Twist in, the are liken to light bulbs and if you twist it in, it will break the filament and make the sensor useless.
Jim
'85 Carrera Targa
PCA/POC
Old 11-11-2011, 07:01 PM
CDN Redneck
Capt J.D.'s Avatar
Thank You all for the clarification..(and the heads up on twisting the sensor) I believe that "Tippy" has asked about twisting the sensor so I hope that he has read this post.
Old 11-11-2011, 08:17 PM
One tube also , my speec sensor was so stuck
I had to cut it in half " a drill holes thru it
To knock it out. It was ridicoulous I then used a
Dremel with a wire wheel to clean the case. This was
A time consuming little project to do both the sensors.
But afterwards car has never run better. Idle surging
And second try starts instantly gone.
Old 11-12-2011, 06:40 AM
