No left side running lights
79 SC ....Noticed tonight that my left side tail light was out and when I walked around the car..the front left running light was also out. Pulled the lenses, checked the bulbs, looked at the sockets and went to the fuse box. Fuse #4 was blown and when I replaced it, the new fuse blew as soon as I pulled the light switch. I am an electrical minus ...where should I start ?
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Member 911 Anonymous
There is a short in the system, most likely a ground in the rear housing possibly the front but rare.
Check to see if the ground came loose or worse the PCB type contact has not broken, if broken JB weld a piece of plastic to re-build the PCB type contact board: ![]() Mine actually cracked in half due to all the years PO was smashing the bulb into place think it would make a better contact, NOT ![]() Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I hate freight charges
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
Thanks guys...I should also have said that all other functions are good on that side ... flashers, turns, brakes, back up lights. I will try to find the ground issue tonight and let you know. According to the Bentley, I can remove the rear housing fairly easily. The front requires removal of the bumper...Grrrrr !!!
Fleabit peanut monkey
Disconnect the wires from the engine bay light and see if the fuse does not blow.
muck-raker
I'm with Bob on this one. It sounds like a classic case of the engine bay light having an issue. The left side running lights route right through this system. Check your light fixture very carefully.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Betcha! |
shoulda Betcha Bob,
It was a pinched wire in the rear of the rear tail light housing and now she is good to go..until the next time on this wonderfully cranky 32 year old girl. Thanks for your input...gotta love this forum...everybody steps up to the level of their ability !!! My learning curve is steep right now and will get steeper as I get more familiar with "Molly".
Thanks for clarifying the resolution. Finally, DRACO and Village Idiot, at long last, have some "street cred"
AH SHUCKS, Jim...U B blushin :=)
muck-raker
To steal a line from Capt. James T. Kirk: "Dammit, Jim!!!!"
Spot on diagnosis. You rock!!!
