Porchcar guy's Avatar
No left side running lights
79 SC ....Noticed tonight that my left side tail light was out and when I walked around the car..the front left running light was also out. Pulled the lenses, checked the bulbs, looked at the sockets and went to the fuse box. Fuse #4 was blown and when I replaced it, the new fuse blew as soon as I pulled the light switch. I am an electrical minus ...where should I start ?
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 11-21-2011, 08:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
There is a short in the system, most likely a ground in the rear housing possibly the front but rare.
Check to see if the ground came loose or worse the PCB type contact has not broken, if broken JB weld a piece of plastic to re-build the PCB type contact board:
Mine actually cracked in half due to all the years PO was smashing the bulb into place think it would make a better contact, NOT
Jim
'85 Carrera Targa
PCA/POC
Old 11-21-2011, 10:17 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Jim
Exact same thing happened to me. I ended up making new grounds for both tail lights. No problems since
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 11-21-2011, 10:46 PM
Thanks guys...I should also have said that all other functions are good on that side ... flashers, turns, brakes, back up lights. I will try to find the ground issue tonight and let you know. According to the Bentley, I can remove the rear housing fairly easily. The front requires removal of the bumper...Grrrrr !!!
15 year PCA member
Old 11-22-2011, 08:38 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Disconnect the wires from the engine bay light and see if the fuse does not blow.
Old 11-22-2011, 01:31 PM
muck-raker
kidrock's Avatar
I'm with Bob on this one. It sounds like a classic case of the engine bay light having an issue. The left side running lights route right through this system. Check your light fixture very carefully.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-22-2011, 04:10 PM
Bob Kontak's Avatar
=kidrock;6387399sounds like a classic case of the engine bay light having an issue.
I am not sure how easy it is to just disconnect the wires. Pull that bad boy off and make sure the wires are not touching anything and put a new fuse in.
Betcha!
Old 11-22-2011, 04:31 PM
shoulda Betcha Bob,
It was a pinched wire in the rear of the rear tail light housing and now she is good to go..until the next time on this wonderfully cranky 32 year old girl. Thanks for your input...gotta love this forum...everybody steps up to the level of their ability !!! My learning curve is steep right now and will get steeper as I get more familiar with "Molly".
15 year PCA member
Old 11-23-2011, 05:32 PM
Bob Kontak's Avatar
Thanks for clarifying the resolution. Finally, DRACO and Village Idiot, at long last, have some "street cred"
Old 11-23-2011, 05:42 PM
DRACO A5OG's Avatar
I am humbled BK
'85 Carrera Targa
PCA/POC
Old 11-23-2011, 08:30 PM
AH SHUCKS, Jim...U B blushin :=)
15 year PCA member
Old 11-23-2011, 11:31 PM
muck-raker
kidrock's Avatar
To steal a line from Capt. James T. Kirk: "Dammit, Jim!!!!"
Spot on diagnosis. You rock!!!
STONE
Old 11-24-2011, 12:52 AM
