LinkBack | Thread Tools | Rate Thread |
I'm going to change my oil tomorrow - thinking of adding Seafoam today
I'm wondering what the experts think....
I'm going to change my oil either tomorrow or Friday and so I was thinking of adding a can of Seafoam to the oil today - as a general engine cleaner. I've heard of people adding Seafoam to the oil but I hve never done this myself. Are there any benefits to doing this? Thanks.......Vern |
Mike Holbrook
I generally add Seafoam to gas to clean the injectors. I don't know about to the oil. Lots of us "old timers" grew up adding a quart of ATF to the oil for a couple days before an oil change. Very high detergent. I don't know how this would go over with our Porsche people.
Mike Holbrook Meridian, ID 1979 911SC Targa |
I would only do this if I had a problem I was trying to fix. Maybe a stuck ring or clogged cam spraybar. If your car has had regular oil changes and has no issues, I wouldn't do it. Best case is nothing bad happens, worst case is some sludge comes off and clogs a bearing, spraybar, piston squirter, pressure relief valve, etc.
-Andy
72 Carrera RS replica, Spec 911 racer |
I wouldn't, either.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Don't do it.
I dig SeaFoam but only as a fuel additive. If I had a car with issues I may try the vacuum hose route but not in a good running engine.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Member 911 Anonymous
+1 Don't do it!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Got it. I won't do it. My car is in good shape and just needs and oil change. It was only a thought.
I still add the AFT to some of my vehicles, but not my Porsche. It's unbelievable how clean the engine it is upon diassembly.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
No.
I've put it in the oil of a 3.2 that wasn't running well. Cleaned out the mosquitoes from the whole neighborhood.
Didn't solve the problem, replacing the speed/reference sensors did, but didn't seem to hurt the engine, and that was a lot of miles ago. Does wonders for snow blowers, lawn mowers, etc. Like other have said, if it ain't broke, don't fix it. I wouldn't put it in unless I was having a problem. Just my .02 |
RETIRED
Put it the gas and run it for a couple of days.....it'll end up in your oil anyways.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
muck-raker
I used to run a can of B-12 Chemtool through my oil for about 100 miles before an oil change in many of my old cars, just to clean up the crankcase. It never hurt anything.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
more info, just curious ....through the valve guides?
76' 911s Signature Edition |
RETIRED
Seafoam washes down everything past the rings and your oil ends with all the crap it breaks loose. It's recommended that after you do a treatment that you change the oil....
oh, yeah, duh... I meant rings, didn't think about the crud, though
