<insert witty title here>
No start, but a bit different
Any ideas what might be causing this? It wants to start - it will turn over once or twice every few seconds. Electrical connections are all good, at least on a 2-minute inspection. Fuel pump fuse is fine. It started fine yesterday when I backed it out of the garage, sat overnight outside (no rain) now this. Here's a video:
http://www.youtube.com/watch?v=SYNt2MeSdX8&feature=youtube_gdata_player |
Member 911 Anonymous
Shame on you sir for letting your baby sit out in the cold Ontario weather :-(
Check the voltage on the battery, it may not have enough amps to start her. J
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
It was 10 degrees yesterday!
(celsius, that is)I just put the charger on and it was indeed showing only about 60%. I always assumed that it would either start or fail to turn over the starter and crank at all. We'll see if this gets it. |
That will do it and 10c will weaken her as well. You should be fine Ontario, eh
Nope, that didn't do it. Put the charger on for a couple hours, and used a booster pack. Same thing. I had it out to boost the minivan yesterday (my wife left the interior lights on again...) but I can't imagine I did anything to mess it up - I've boosted hundreds of cars.
Hmm, no click no nothing?
OK, check the ground at trans and the connectors at the starter/solenoid.
No, it's cranking and tries to fire ocassionally, just like in the video. I'm going to have to start checking the regular things.
a '72, hmm Sorry can't help on the ignition issue, but I remember reading another poster about something to do with his pop off valve or something like that???
Break a Leg Brother!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 11-25-2011 at 08:17 PM.. |
That's CIS. I know what to do, was just hoping someone might have a flash of brilliance.
Does the engine compartment smell like gas? If not, my guess is fuel starvation. I had a very similar problem in my old mercedes. After a lot of guess work, I found out that the weber carbs had another fuel filter in it. When I opened it up, it was loaded with crud. Weird thing, I had driven it for about 2000 miles before that happened, not sure why it happened out of nowhere. You could have someone trying to start it while you force carb cleaner down the carburator to see if it is fuel delivery.
If it smells as though the engine was flooded (a lot of gas smell in the engine bay), my guess would be electrical. You may be getting weak/little spark. A good way to check this is if you take out a spark plug and the plug is wet. Thanks for the youtube, makes it MUCH easier to diagnose.
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Definitely getting some fuel smell. My fuel filter is mounted in the engine bay for easy access to replace, so I pulled that off to see if it was clogged - gas is flowing through just fine. I pulled the air box off and squirted plenty of fuel to fill the bowls by hand. No go. I hooked up the timing light to check for spark, and I'm getting spark, at least on one cylinder.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Any ideas?
OK, it you have fuel delivery, then it is probably electrical. I would check the spark at all three plugs. Take out each spark plug and look at the spark you are getting. also, examine each plug to make sure that they are wet with fuel (to double check they are getting fuel). The spark should be strong. the 2 times my car sounded like yours, it was 1) clogged carburator, and 2) bad spark. My bad spark due to moisture in the air on my old ignition system. I upgraded to electronic ignition and after some fumbling, I eventually got it to work.
I don't know how, but does anyone know how to measure the amount of spark rather than looking at it? For instance, can you hook up a multimeter to the coil? What voltage are you supposed to get? BTW, Christien. I am heading to toronto tomorrow on business. I'll wish you good luck when I get off the plane.
Spray some carb cleaner dcown the stacks and crank. Should act like starter fluid.
Chris 73 911 E |
Fleabit peanut monkey
Is there a choke on the carbs? I have CIS and I did mess with a Rochester carb - that one time - so I am no expert.
It sounds like it is not getting enough air but that is a guess. |
RETIRED
Spark, fuel (pressure on 70 psi + on CIS) and air.
Pull a plug wire, put another plug in the end, crank motor with plug close to a ground....you'll know if you have spark or not. Fuel pressure....shot of ether and it coughs, it a fuel problem. Lifting the flap inside the air box will let you hear the pump going....if not prolly a relay under the front hood drivers side. Pump runs, may not be enuff pressure....you'll need gauges. Air.....well check the intake filter.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
So have you had any luck?
I haven't had a chance to dig it into. I pushed it into the garage a couple days ago, and it's sat. It's off the road for winter, anyway - the salt trucks have been out in full force this week. I'll get to it this weekend and see if I can get it started. Just one more thing on a long list of small projects for the winter.
When you pull a plug wire to test, can you hold the wire with your bare hand while cranking? I always assumed that, since the timing light can sense the current pass through, it might be dangerous to hold the wire.
RETIRED
Bare hands and cranking to check start? Sure, if ya want yer sperm to do the 'Macarena".
Gloves and/or an insulted set of pliers will work. Hell....borrow the old lady's rubber dish washing mitts. Or better yet, have her hold it.
The dancing banana is feisty today.
Just lay it on top of the valve covers while your helper turns it over. You will see spark if it's there. It kicks real hard when you eat secondary voltage. I don't care for the sensation at all. Not one little bit. |
