NO LIFT's Avatar
Spark plug connector
Changing plugs in my '88 Carerra today, I broke one of the spark plug connectors.
I would rather not replace all the wires.
I found that our host has replacements:
Pelican Parts - Product Information: 911-602-315-00-M47
What is the procedure to replace the connector?
Advice appreciated!
2003 996 Carrera
gone but not forgotten '88Carrera '96 993 '89 951
Old 11-27-2011, 12:45 PM
Deadeye's Avatar
The beru wires have a threaded connector crimped onto the wire. Lubricate the wire at the connector and unscrew it.
Old 11-27-2011, 01:42 PM
ROW '78 911 Targa
timmy2's Avatar
I believe you can just pull back the boot and yurn the old connector off.
Installation is the reversal of that process.
Try to turn your wire out of the broken one before you place your order.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-27-2011, 02:00 PM
NO LIFT's Avatar
Thanks for the replies!
I loosened the rubber seal from the spark plug connector, sprayed a little WD-40 in, and gently tried to unscrew...and the wire came out - no threaded terminal on the end.
So, now what?
2003 996 Carrera
Old 11-27-2011, 03:58 PM
ROW '78 911 Targa
timmy2's Avatar
Look in the connector. There should be a small screw facing you. It may be removable or fixed depending on the brand you have. There should also be a corresponding hole in the end of your wire.
Dennis
Old 11-27-2011, 05:51 PM
NO LIFT's Avatar
Here's what I've got:
Advice greatly appreciated!
2003 996 Carrera
Old 11-27-2011, 05:53 PM
ROW '78 911 Targa
timmy2's Avatar
The wire should just screw into the piece that you removed. (Look in the hole of the broken piece)
There should be a screw in there(the removed part) that will cinch the wire in tight and provide a conduction path from wire to plug.
Dennis
Old 11-27-2011, 05:58 PM
