advtracing's Avatar
whats the ideal weber set up?
Guys i have a euro 76s 2.7 with cis , i am ripping off the cis and going webers (i hope) what is the best set up i;e
- 40's or 44's
- what jetting would you recommend
- any additional information that would help?
"Funding my obsession one nut at a time"
Old 12-05-2011, 06:57 PM
gumba's Avatar
I'd skip the Webers and go with 40mm PMO's.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 12-05-2011, 07:15 PM
40's with 34 vents is perfect for me
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2011, 08:14 PM
advtracing's Avatar
are you running std cams the compression (cis set up on carbs?)
Old 12-05-2011, 08:29 PM
RETIRED
Joe Bob's Avatar
40 Zeniths would be cheaper......
2012 ML350 3.0 Turbo Diesel
Old 12-05-2011, 08:47 PM
a 2.7 per rpm needs a fixed amount of airflow that 34 vents satisfy
i am using e-cams and 8.5:1 pistons
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2011, 09:30 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
There are some great posts in the engine rebuilding forum of guys going through this exactly and a lot of advice from others. You should check them out. If I was on my computer instead of my iPad this evening I would send you some links.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-05-2011, 09:55 PM
Carbs will work great on this engine. I'd use any of the set-ups you find on here to start with. You really will want to dyno for fine tuning, or buy a wide band O2 meter. I have a cheap WB O2 meter in my car and it is a Godsend for tuning.
-Andy
Old 12-06-2011, 11:45 AM
KTL KTL is offline
Schleprock
KTL's Avatar
-Andy
I'll second that. I put a AEM wideband analog gauge in my racecar and it's a great tool for tuning and monitoring fuel delivery behavior. It pays for itself very quickly. It's like having your own dyno at home before you take it to the dyno.
Kevin L
'86 Carrera "Larry"
Old 12-06-2011, 11:49 AM
