Uno Dei Molti Porschisti
BarryJB's Avatar
Question 3.6 conversion - 993 engine hanger question
Would these 1.4-in offset adapters for the 993 hanger - courtesy of Rick (silver911rdb)* - work for putting a '95 3.6 into an '85 Carrera with a 915, rather than bending it? Going to a single pulley, but the 3.2 hanger's nixed as A/C's staying.
Or is some other offset required - one 3.6 conversion pic in these forums showed a different, smaller (≈1/2-in) bent offset.
*I found Rick's post (#16) at Let the 3.6 fun begin and below is a drawing I made using Rick's original sketch (hope posting this drawing was OK, Rick)
Thanks folks!
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 01-06-2012, 12:59 PM
loose nut behind wheel
cudabnu's Avatar
I just bent mine and welded a reinforcement on the back of each side, worked great for me,
I was going to go the adapter route, but it was no prob to bend and weld -vs- having the adapters made.
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 01-06-2012, 01:35 PM
Here's what they look like installed.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 01-06-2012, 01:39 PM
cudabnu's Avatar
here was mine:
Old 01-06-2012, 01:52 PM
BarryJB's Avatar
Cudabnu, thank you, and that's a nice-looking job on your hanger, too!
Uwanna, my thanks to you! It was seeing these same pics of your hanger a month ago (followed the link in your post in that link I quoted above) that set me off in that direction - really like the idea!
I was completely content this was the way to go until seeing some conversion pics showing a smaller offset on the hanger, so it's really the amount of offset I'm worried about. Both your cars, and the others here I can find where pics are posted, appear to be earlier 911 tubs - 74 thru 80 - and I just want to make sure my later car requires the same offset. It may just be the different offset is for cars using a G50, or something else NA to my conversion.
I have a machinist buddy I'm trading favors with, and he's going to make the adapters and weld it all up with the one-piece Rennline reinforcement gusset (see their pic below), I just want to make sure on the offset before he goes to town!
Old 01-06-2012, 02:08 PM
cudabnu's Avatar
it's good to have friends with skills!
Old 01-06-2012, 02:18 PM
BarryJB's Avatar
Helps to have one to trade too - trading machining/welding for electronic design
Old 01-06-2012, 02:21 PM
