pszemia's Avatar
Help with CMA part load without protractors
Hi everybody, i've been today mkaing some adjustments according to CMA to my car.
I have found a place with a dynamometer which i can use for some time to make the part load adjustment.
As i said on posts before, i have a gunson gastester.
The main problem i have is i don't know how to put the throttle valve to the 9º degree the CMA specify.
I have made some tests and adjustments today with the car in 2nd gear on the dynamometer and at 3000RPM, and now the car is at: Part load: 6% CO, Idle: 6.5% CO, according to gunson gastester.
I know the CMA says at 2400RPM, but it says with the throttle angle, which i don't know how to reach.
What do you think of this method? is that right?
Thanks a lot!
Ariel
911 T 2.4 (MFI) 1973 with 911 E fuel pump from 1971
The beatiful Buenos Aires, Argentina!
Old 12-16-2011, 12:42 PM
pszemia's Avatar
any help??
Old 12-22-2011, 01:22 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Cma?
Old 12-22-2011, 02:50 PM
around 6% at idle and at 3k is pretty close. if it starts good and accelerates without any lag or flat spot, life is good. you could try it a tad leaner, but that often gets you a flat spot.
206 637 4071
Old 12-22-2011, 03:29 PM
pszemia's Avatar
john, so 3000RPM is like 2500RPM under load?
Old 12-22-2011, 03:58 PM
