too many projects 1983 sc
56 nomad's Avatar
how much of a problem is this o2 sensor
Hi guys,
Posted a similar image a few days ago, this is what i found on further inspection. The plastic is broken, on the pin receiver ( I don't know what it is called ), the wire is tight and is not broken. Do I need to replace this? Or, can I just plug in the oxygen sensor wire?
Smog test on Wednesday. Any help would be greatly appriciated. can i epoxy this with no problem?
Best reguards,
Ben
Old 01-06-2012, 01:12 PM
E Sully's Avatar
As long as it is electricaly OK you can just plug it in for now. It is very common for this to fall apart from age and heat. Some have soldered and used heat shrink. Here is a link to one guys repair from a couple of years ago. The one wire is the signal of the o2 sensor, there are also 2 wires for the o2 sensor heating, which brings it up to operating temperature sooner.
O2 Sensor connector
Ed
1973.5 T
Old 01-06-2012, 01:37 PM
dshepp806's Avatar
Yeap,..as ugly as it looks, it's a matter of what she's signalling...
STILL,..out, it goes!
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-06-2012, 03:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If you can try to build it up with some JB weld or epoxy. It was specially designed to take an air sample.
If you fail solder a bullet type connector but make certain the solder is rock solid as not to get errand readings
'85 Carrera Targa
PCA/POC
Old 01-06-2012, 03:53 PM
56 nomad's Avatar
O2 Sensor connector
thanks to all ..great info did not know there was a special part made for this purpose....will try the epoxy or jbweld Draco recomendation first...more things to do and less time to do them.
regards, ben
Old 01-06-2012, 05:08 PM
byfdinky's Avatar
I hear if you buy 02 sensors from Autozone, they come with a lifetime warranty!
-Bill
1979 911 SC Targa
Old 01-06-2012, 05:21 PM
crustychief's Avatar
The problem is on the car side. No warranty, except from Porsche, will honor that.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 01-06-2012, 05:52 PM
mca mca is offline
mca's Avatar
Contact Louie85. He sells a nice replacement kit. Very high quality plug.
Old 01-17-2012, 06:10 PM
