too many projects 1983 sc
how much of a problem is this o2 sensor
Hi guys,
Posted a similar image a few days ago, this is what i found on further inspection. The plastic is broken, on the pin receiver ( I don't know what it is called ), the wire is tight and is not broken. Do I need to replace this? Or, can I just plug in the oxygen sensor wire? Smog test on Wednesday. Any help would be greatly appriciated. can i epoxy this with no problem? Best reguards, Ben
As long as it is electricaly OK you can just plug it in for now. It is very common for this to fall apart from age and heat. Some have soldered and used heat shrink. Here is a link to one guys repair from a couple of years ago. The one wire is the signal of the o2 sensor, there are also 2 wires for the o2 sensor heating, which brings it up to operating temperature sooner.
O2 Sensor connector
Ed 1973.5 T |
Yeap,..as ugly as it looks, it's a matter of what she's signalling...
STILL,..out, it goes! Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Member 911 Anonymous
If you can try to build it up with some JB weld or epoxy. It was specially designed to take an air sample.
If you fail solder a bullet type connector but make certain the solder is rock solid as not to get errand readings
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
regards, ben |
I hear if you buy 02 sensors from Autozone, they come with a lifetime warranty!
-Bill 1979 911 SC Targa |
The problem is on the car side. No warranty, except from Porsche, will honor that.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Contact Louie85. He sells a nice replacement kit. Very high quality plug.
