Shock but torque down help
Hi all
Could you please help me work out how I torque down the front shock tower nut as it spins as there doesn't appear to be a sensible way to hold the shock to stop it turning Thank you |
Reiver
I work alone so normally count the exposed threads (try the other shock) and use a small impact wrench (3/4) to place the nut in that same position. It won't spin with the IW. I did both of mine in that way long ago.
Just did this with the ball joints yesterday...no way I could hold the tool in place and torque to 184 without putting my body into it.
De Oppresso Liber Strength and Honor 5th Legion |
Member 911 Anonymous
+1 a shallow wide socket lodged against the spanner opening and the fender, but tae cae this may bend the fender.
I believer you can rent for FREE a spanner wrench at a FLAPS
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you
