HJT911's Avatar
What is that ?
Having dissasembling of my 911 now finished, paintwork and replacement of a bulk of parts finalized I'm now on the way to rebuild the car. Some Photos attached.
Whereas up to now all of the parts find there way back to it's place of origin, there is one I can not allocate. Hope one of you can help.
Some pictures of my project
Carbon Roof
Oil Lines Inside
Motor and transmission, compl. refurbished
Motor wraped in new "Cloth"
Front mounted Oilcooler
new paint
964 brakes and new zinc coated dust sheets
Old 12-27-2011, 01:53 PM
Northern Motorhead
wildcat077's Avatar
That garage looks too clean
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-27-2011, 02:06 PM
Throttle body? Rod from gas pedal linkage on one end and return spring on the other. Just a guess.HTH Jim
Old 12-27-2011, 02:12 PM
sudo apt-get purge 930
equality72521's Avatar
Looks like the lever on the throttle cable pivot plate on the rear or the engine.
--clutch-monkey
Bill Verburg's Avatar
It looks like part of the mechanical brake lever linkage from a 3.2 Carrera
Bill Verburg
Old 12-27-2011, 05:37 PM
That car looks better than new. Nice work!
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 12-27-2011, 05:40 PM
mtech325ic's Avatar
How or where did you get the carbon fiber door panels?
Kevin
'86 Carrera
Old 12-27-2011, 05:42 PM
Walt Fricke's Avatar
HJT - hard to tell without some sense of scale for its size.
I don't recognize it. It looks like it has an oilable bushing (as Bosch uses in some of its motors) where it pivots.
Not part of the throttle linkage.
I don't remember the hand brake needing a bell crank anywhere to reverse a motion (and multiply it) - so I checked in my parts manual (1977, but this is a 911 so the little stuff seldom changes) - no, not part of the E brake.
In the door? Nope. some bell cranks, but not that shape. At least not for manual lock doors.
Fresh air system? Nope, and most of those have the pivot turn a valve anyway so they don't just come off.
Automatic heating controls? Don't think so.
Windshield wiper mechanism? Didn't look like anything in the diagram.
How about it is a part from your long lost MB-B?
Old 12-27-2011, 08:03 PM
1980SCMan
Alan Lindquist's Avatar
How about the throttle rod linkage pivot that slides on a shaft coming off the transmission?
Old 12-27-2011, 09:17 PM
HJT911's Avatar
Hi Kevin,
door cards are self-made ( cut and drilled) from 2,5mm carbon plates.
Old 12-28-2011, 12:06 AM
Alan
Nope
That has a long pivot shaft, and the connections are both on the same side of the pivot because it does not reverse the direction of the pull. It just redirects it from sort of horizontal to an up angle. Might have a small change in mechanical advantage or disadvantage.
Old 12-28-2011, 03:17 PM
Verry nice lookin car / project. That part is from the Cargo door on the Space shuttle, very rare, more rare that your run-of-the-mill Porsche RSR parts.
73 911 T MFI Coupe, Aubergine
Old 12-28-2011, 03:56 PM
Brorag
Brorag's Avatar
I agree with Lindquist:
Old 12-28-2011, 08:21 PM
1980SCMan
Thanks, Brorag, but I think I'm wrong and agree with the guy who disagreed with me. The part I'm thinking of does have a long receiver shaft that keeps it off the tranny (at least on the 915). The part shown is pretty flush.
It definitely seems to be a pivot shaft though. Push on one end... pull on the other.
I have a bowl on my work bench for stuff like that. Throw extra parts in there and go fishing when you're wanting. NEVER throw a part away. As soon as you do, you'll need it within a week.
Old 12-28-2011, 08:37 PM
