Hi
Targa Me's Avatar
Separating 915 from Engine
Hello All.
I've got my 3.2 out and I'm trying to separate the trans from the engine and it's not budging. I've got it split just a little bit but not much.
I had this same trouble last time (100k ago) but I don't seem to remember it being this much trouble.
Do you guys have any tricks I need to know about ?
Frustrated.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 12-30-2011, 12:28 PM
This thread 1980 3.0 - Seperating Trans from Eng probs I believe explains the trick you are looking for. It worked for me.
Old 12-30-2011, 12:36 PM
j911brick's Avatar
Did you take the arm off the bottom?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-30-2011, 12:37 PM
Hi
Targa Me's Avatar
Ok, I got it.
I forgot to take the arm off the bottom. Once I did that all was good.
Thanks Pelicans !
Old 12-30-2011, 12:50 PM
Yes. I'm in the process of replacing the clutch and performing general maintenance. That includes removing and lubing the clutch release shaft, and replacing the seals. The release fork is connected to the TO bearing. Remove the positioning lever and the tranny should slide out with ease.
Old 12-30-2011, 12:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Damn L,
Call me next time, I will be up to help
J
'85 Carrera Targa
PCA/POC
Old 12-31-2011, 11:06 AM
