Drop Engine - To Do List ??
Help me out. I did my first engine drop on my 911 and have a lengthy "while I am in there" list but want to make sure I do not miss anything. I am doing my share of engine and compartment detailing along with the following. Anything I missed let me know.
> Clutch > Valve Adjustment > Oil Leaks > Fuel Filter What am I missing? Thanks
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Member 911 Anonymous
The trinity: Oil Breather Gasket, Idiot oil light switch, Termostat Oring
Heck, a new Fuel Pressure Regulator, it is biotch in the car, almost impossible to get the proper torque.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Rescuer of old cars
Fuel lines?
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Clutch?
Throw Out Bearing, Guide Tube and don't forget the SEAL Pilot Bearing Fork Gear Lube while she is sitting level.
Speed and reference sensors?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Compartment sound mat.
Does your year have the "spider" air injection from the air pump? Good time to remove all that and plug the ports.
Intake gaskets Detail fan, fan housing and valve covers.
Ken 1986 930 2016 R1200RS |
You'll find plenty when you drop it. My original clutch replacement cost me almost $2k in parts.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Vacuum hoses..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Eschews Obfuscation
+1 vacuum hoses
+1000 fuel lines any rubber part should be replaced at this point also, inspect the throttle cable and linkage to ensure you're getting full throttle. might as well lube the mechanical linkage as well.
'84 Porsche 911 Targa '97 Ford F250 Heavy Duty '98 Volvo S70 '02 Subaru Forester '05 VW Passat TDI |
Clean the engine compartment/engine and paint things if you like. Engine/tranny mounts if need be.
72 911 Although it is done at the moment, it will never be finished. |
French Import
How are your rear shocks, bushings, etc...? A lot easier to do with the engine out.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Banana arm bushings too. Another plug for Elephant and their monoballs.
AutoBahned
do a search on engine + drop + list to find the other threads - do it while the engine is already out so it can be added to this list...
ROW '78 911 Targa
Finally, back in the game!
Pick yer poison from the list of things I did "while I was in there". ![]() Took her out for a nice cruise today in the 50 deg Oregon sunshine and she's running great.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 01-28-2012 at 03:45 PM.. |
