Stumped the group?
84 911 - 88 944 Turbo S - Sold
996 Turbo
996 Cab
Old 03-20-2012, 08:14 AM
I had a problem like this in a Volkswagen years ago and it was a bad ground wire from the battery to the engine block.
Old 03-20-2012, 08:20 AM
Since I can't get any bad readings from the alternator, I'm going to replace the ignition switch electrical part and have the tumbler assembly serviced by a locksmith. Seems like it's easier to pull the whole thing out, rather then spend an hour trying to get the top screw of the electrical switch off the back from under the dash.
996 Turbo
996 Cab
Old 03-20-2012, 09:37 AM
Originally Posted by djbrand1 View Post
Yeah, well the engine not stopping is a new issue unfortunately. I was able to get the engine off by cycling the key a couple times and cringing while the starter engaged a couple times.
Before the engine not turning off. I was testing a DIY heater relay that I built for the autoheat controller int he back. Plugged it in and the heater fans functioned like normal, but I pulled the key and the radio went off, but the dash warning lights were on and I was still able to operate the headlights. odd. I started it up and shut it off and everything went off like normal so I took it out for a quick drive. Ran fine, minus that tach doing it's weird thing, got back, removed key and engine was still running.
Got rid of the engine not stopping with the key off issue. I replaced the ignition electrical portion without fixing it. Pulled the "rigged" relay for the heater out and viola, car shuts right off. Didn't think those circuits were related in anyway but that did it.
So even with the new ignition electric switch I am still getting a crazy tach. Would fried alternators diodes cause overcharging too? I get a flat 14.2-14.5 volts with the engine running at different revs.
996 Turbo
996 Cab
Old 04-11-2012, 06:09 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diodes.
Originally Posted by 304065 View Post
Bouncing tach with key off = fried alternator diodes
Correct!
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-11-2012, 07:26 AM
But I have no symptoms of overcharging..... Taking it to an electrical specialist for them to test. Tried a couple different meters and they all reported a steady 14.2 volts while the tach was doing its dance.
996 Turbo
996 Cab
Old 04-11-2012, 07:49 AM
Overcharging.
The overcharging, as per the write-up is intermittent.
My bet is still on the VR diodes.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-11-2012, 07:57 AM
Had the alternator checked out at a local shop. They couldn't find anything wrong. It is a Bosch Reman. Put everything back in the car and I am still getting the wacky tach. While I had the alternator out, I cleaned up all the connections behind it, and the wires looked fine.
Next up, pulling the gauge and sending to Hollywood for diagnosis? Or just replace the regulator on the alternator for the hell of it?
996 Turbo
996 Cab
Old 05-14-2012, 10:52 AM
My $.02.
My tach on the 1982 was intermittent and jumping around. Mechanic said it was the voltage regulator, which was repaired. Problem was fixed.
Bob D
1982 RoW Silver 911SC - PCA E #339
1997 993 Turquoise Blue Carrera S
Old 05-14-2012, 11:20 AM
Yeah, I ordered a new regulator. I was still leaning towards it as well, and I should be able to get the alternator out and back in a lot quicker this time around. I'll let everyone know.
996 Turbo
996 Cab
Old 05-14-2012, 06:29 PM
Well, put in the new regulator in and the tach is still flying around about 50% of the time. The shift light indicator is working correctly it seems. I don't think its a grounding issue with the gauge, unless something else is wrong with it. How often do these tachs fail?
996 Turbo
996 Cab
Old 05-20-2012, 07:08 PM
bump
996 Turbo
996 Cab
Old 05-21-2012, 12:41 PM
Bueller?
996 Turbo
996 Cab
Old 05-23-2012, 12:13 PM
I don't have an answer but at least I read your posts before responding.
Rick
88 Cab
Old 05-23-2012, 12:53 PM
Im going with the flux capacitor on this one..
Ok I dont know if your tach is like mine but if it is:
Take out the tach and measure voltage.. an analog meter is ideal for fluctuations..
You should have a ground, a 12v and a signal I think.. If you have some power somewhere (almost certain) try and track it down.. what has capacitance in it on your car, Im not sure.. find out whats all on the fuse that you are seeing the power at.. I gotta think its getting something on the 12v line.. disconnect the alternator and see what happens.. I dont get how diodes would do this.. although there could be a magnetic build up in the alternator and there is the power....
this what i would do.. Im only jumping in because of lack of response.
After re-reading.. What the heck is going on with rigged relay? this must be sorted out first..
JP
'76 911s Ice Green Metallic bone stock
Old 05-23-2012, 01:15 PM
Pin 2 on the tach comes from pin 21 of the DME.
  1. When the ignition coil is charging this pin presents 510 ohms to ground.
  2. When it is not charging the coil it looks like 2000 ohms to 12 volts. I would assume this is the state with key on engine off.
You could try to duplicate condition 2 without a DME.
And while you're in there check the condition of the brown wire.
Rick
88 Cab
Old 05-23-2012, 01:35 PM
dshepp806's Avatar
Get the tach to NHS......remove any "rigged stuff"......
Did you get a different voltage reading with the new VR?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-23-2012, 01:39 PM
Doyle
Send the tach for repair? I dont know that its the tach.. How do you know its the tach? Isnt he seeing it moving when power should not be applied?
JP
Old 05-23-2012, 01:45 PM
dshepp806's Avatar
Probably a bit premature,..sorry,....in re-reading, you are right,..he's seeing the action when the ignition switch is off (as you're contending). ...a new ignition switch, at that.....sure smells like some wiring could be the issue.....time to chase and trace....
In that case,...find where the (errant) power is coming from...
Best!
Doyle
Middle Georgia
Old 05-23-2012, 02:00 PM
The rigged relay is out of the picture now, replaced with a working used one. Thanks!
996 Turbo
996 Cab
Old 05-24-2012, 04:54 AM
