rear sway bar mod SWB
all;
ran a search but came up empty. if this has been covered, please kindly direct me to the appropriate thread. I'm getting ready to mod my '66 to accomodate a rear bar. I'm trying to locate the perchs on the tub. is there a template for this? any help appreciated. TIA jerry ![]()
Max Sluiter
Attach them to the bar and mock that up, then tack the brackets in place.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Bird. It's the word...
Danger Will Robinson!
Those are later (74) consoles... the earlier cars had different sheet metal and a different shaped consle which matches the contour of the sheet metal.
John Forcier Current: 68L 2.0 Hotrod - build underway |
I thought of that too, but i'm not clear on how & where the drop links mount. control arm ? spring plate ? different manufacturers use different points. I don't care for the adaptors i've seen & have no intent of going that route.
understood. when I first bought these I didn't know there was a difference. I've since seen SWB consoles & don't think I'd use them as they seem awfully light duty. the later ones need to be spaced in from the bulkhead about 1/4 " - 3/8" per side. the early ones don't seem like they make up this mismatch either. (not sure this is making sense) I'll post some pix on what I've done so far.
Max Sluiter
Aftermarket usually mount to the spring plate using a substitute bolt. Weltmeister has a special eccentric bolt that replaces the stock one and has an extension on the backside to mount their drop links.
I would rather be driving
Ed Mayo did a thread on the Early S Board updating a SWB.
I will see if I can find the link.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks Last edited by jpnovak; 02-06-2012 at 09:36 AM.. |
looks like here;
rear sway bar install there is still some lack of clarity & i may need to decide what product i want to use & do the mock up with that. there doesn't seem to be a template for where to mount the consoles. |
pix of my modified consoles.
Your mount is too high. In that position, the sway bar is going to intersect the trans mount.
Use your bar to help position.
Chuck Moreland - elephantracing.com - vonnen.com |
Your 66 911 rear trailing arms do not have the ball fitting for the drop link to mount to for a factory swaybar. The ball end pins are available from Porsche and require some careful measuring and lay out work before welding. Your trailing arms will have to be drilled to accept the pins, if you go with the factory setup. Can get you the part# if you need it.
Forgot to mention that the aftermarket sway bars usually are mounted lower than the factory bars. A little more visible looking at the car than the stock setup and a little less clearance.
Home of the Whopper
Are there other options to mount a stock factory sway bar without the ball fittings on the trailing arms? The existing trailing arms have dimples where the ball would be, so maybe not a big deal to add the pins? Maybe fit the weltmeister setup to the spring plates?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Max Sluiter
I have the Weltmeister but the better way to go is Tarett.
Ty, Why not spend about $70 and get the early sway bar mounts. These go on really easily and there is no build up of metal require to fit them between the early/late pinch weld and seam styles?
Absolutely, you must attach the bar and make sure you have clearance across the car. High and tight is good, touching is not.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Buckley has a great bracket that butts up to the torsion tube.
Take a look at it. Buckley Racing - 911 Car Prep |
FWIW, I installed a factory bar on my '69 - way back when. I suggest welding the ball pins into each control arm first. Those pin locations help locate the remaining parts of the SB.
It helps to have the car on a drive-on lift as equipped at a muffler shop. That way, the control arms are in position at the normal, at-rest ride height. Install the drop links to the installed ball pins, then to the ends of the bar. Swing the bar upward toward the undercarriage. This allows you to identify and position the SB console accurately for welding. The objective is to mount the bar so it rotates with the suspension movement w/o binding and without adding preload to any side while at rest. Tack weld each console for position, then finish weld. Adjustable drop links are favored for fine tuning and accurate corner balancing, thus the popularity of aftermarket sway bars or upgraded drop links. What's the "improved" WM spring plate bolt? The weakest link of the rear WM kit is/was the marginal 5/16 x 1.5" socket head screw that connects the rod end to the spring plate (it being the most readily available and highest tensile strength in that thread size). Other SB kits use a larger 3/8" or M8 fastener. Sherwood Caveat: Can't confirm installation differences with a SWB 911. Sorry. |
Home of the Whopper
Well, it has dimples. I am assuming it is the right location for the ball mounts.
![]() I have trailing arms from a '70, '71 and '73. All have the dimples.
Yep, that's what I used as a guide with no problems.
