Anybody make there own dial gauge holder for camshaft timing
Would like to know if the zbloc is really needed for camshaft timing or if anybody "easily" made there own dial gauge bracket using stuff around the shop?
Spiderman
Of course you don't need to. I borrowed a fancy indicator from a friend on its mag base and strung a piece of steel I had laying around from a convenient stud. Worked fine.
![]() Eyeballed that I was straight and thats all it takes. Lots of others will post their equipment.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thats perfect !! I have the large magnet on my gauge also. So you just bolted the steel to one of
the valve cover studs? Thanks for the reply. |
Spiderman
Yea, you can't see the bolt. And a thicker piece of steel might have been nice but it worked !
If you have some 3/4" aluminum laying around your garage:
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
+1 on the steel plate - that is how I do mine all the time. If you have the valve cover off you can make one just the right size that it tucks in the cam case - in case you ever want to do it while engine still in.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Chain fence eating turbo
I made a 1/4" strap steel about 1.5-2"'s wide and about 4"s long with a hole in it.
but if you have no aluminium, no steel, but want to do timing
P 964 C2 1992 with some minor changes |
Spiderman
Excellent application, that I like.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Thank you for all the replys.
Very impressed with how resourceful everyone is to "get the job done" vs going out and buying every little tool. This diagram is a huge help, I will for use this to fabricate one. Thanks for sharing. That wood looks plenty solid, I think I may just get a piece of hard wood flooring I have and try to make up the Zbloc Quote:
thanks again
This is going to come in handy with engine drop #2. I used one of those flexible neck things that can lock and it really wasn't all that effective, I had to be VERY careful not to bump it.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
