-   -   Saving the "Rat" - Restoring a 69T (http://forums.pelicanparts.com/porsche-911-technical-forum/660560-saving-rat-restoring-69t.html)
kkinzli 02-14-2013 08:19 AM
Originally Posted by RDM (Post 7271700)
Kristoph,
I've been following this thread (quietly) and am delighted for you the way it turned out. So does having it "finished" feel unreal/strange/elating(?!) or something else?
Congratulations on a great story and a great ride. You've inspired me to take some things on....
Thanks! I am glad to know that the Rat project has inspired you:) Being finished does feel unreal and strange because I have been so focused on the project for the last year. It feels wonderful to enjoy and use the car. It is going to be quite nice to have some spare time for fishing and just relaxing a bit:cool:
bourgeois911 02-14-2013 08:32 AM
Originally Posted by kkinzli (Post 7260096)
Hi Randy,
If you recall my wife is a PhD student which means she does not get a spring break. I plan on doing something like you suggested but it will need to wait until this summer.
If you live in Bonita Springs, where would you go on Spring Break?
kkinzli 02-15-2013 05:37 PM
Originally Posted by timmy2 (Post 7271744)
Congratulations on getting the Rat completed in less than a year from where you started posting, great journey and very well done.
Thanks Timmy! I appreciate the kind words. It has been one crazy year :D
kkinzli 02-15-2013 05:44 PM
Originally Posted by gnashings (Post 7272078)
I'm one of the silent "lurkers"(so much knowledge on this forum that I just shut up and "listen" lol), but I've been religiously following this thread and just can't help myself, I had to chime in with a huge congratulations and an even bigger thank you for sharing this amazing journey. I have learned a lot and have to add that it seems you have a very positive and inspiring way about you, so seeing this project come to life was especially enjoyable and satisfying! Your students are truly fortunate as I'm sure you bring the same enthusiasm and energy into all your endevours! Beautiful car and a job beyond well done, my hat goes off to you, Sir!
Thanks! I am glad you have learned a lot. That means the thread is serving the purpose I intended :p Your kind words mean a lot because in all honesty I feel a little worn out after this crazy year of restoring the Rat. I really appreciate your comment about the enthusiasm and energy because I always try to give 100%. This doesn't always work out but what the heck. I always try to excite my students for engineering because in all reality is there anything cooler? Thanks again for your nice comment. If you are ever "lurking" around in south Florida come over for a beer and say hi to the Rat:cool:
kkinzli 02-21-2013 07:13 AM
It appears that my driver side tail light fix with the JB weld has failed. I think I have found a solution that would work well on the thread below.
http://forums.pelicanparts.com/porsche-911-technical-forum/405209-tail-brake-light-bulbs-loose.html
kkinzli 02-21-2013 09:11 AM
I am going to be spending my spring break doing water research in Colorado at 8,500 ft at temperatures hovering around freezing. This might not be the best idea:rolleyes: Maybe I should stay home and go to the beach;)
kkinzli 02-24-2013 05:42 PM
Shakedown woes: Hi everyone! I have been driving the Rat to work the last couple of weeks to iron out any issues. The first thing that needed attention was a gas leak coming from the tank. It turns out that I didn't tighten the fitting for the fuel line enough and was getting a small drop every 5 minutes or so. I found this problem using my nose. About 3 days ago I thought to myself "I don't remember the garage smelling this bad when I drove the car last a year ago". At that point I took out a flashlight, crawled under the car and saw a puddle and the point of concern. Today I was able to address the leak by tightening up the fuel line fitting.
The culprit! The gas ate away some of the undercoating but not the epoxy primer
http://forums.pelicanparts.com/uploa...1361756191.jpg
A picture of the new brake master cylinder. The car has been stopping like a champ!
http://forums.pelicanparts.com/uploa...1361756351.jpg
Out on the driveway fixing the gas leak
http://forums.pelicanparts.com/uploa...1361756395.jpg
http://forums.pelicanparts.com/uploa...1361756417.jpg
kkinzli 02-24-2013 06:03 PM
Shakedown Woes Part 2: I have been trying to get my rear driver lights to function properly for over a week now. I got a couple of tail light housings from a 71 just in case it was the wiring and to have some spare parts. I have checked everything, made sure the ground is good, and the only light I can get to work is the blinker and the brake light. This leads me to believe that my ground is good. The running lights won't work and I am at a loss as to what is going on. I have taken everything apart, checked the connection and done everything I can think of. Has anybody had this happen before? My next step is to check if I am getting voltage when the running lights are on at the plug connector.
Here are a few pictures of wiring and parts.
http://forums.pelicanparts.com/uploa...1361757693.jpg
http://forums.pelicanparts.com/uploa...1361757726.jpg
kkinzli 02-25-2013 02:19 PM
The Rat's older brother:D
porsche celebrates 50th anniversary of the 911
Jim Horton 03-05-2013 10:09 PM
Nope; nothing cooler. Glad there are still engineering profs like you out there, educating the next round of us.
RWebb 03-05-2013 10:12 PM
Science is cooler...
BTW I've heard people say Loctite 518 works great on fuel hose junctions.
kkinzli 03-09-2013 07:10 AM
Thanks Jim! I have only been an engineering prof for 3 years but plan on doing so for quite some time.
kkinzli 03-09-2013 07:15 AM
Pretty sure Ferdinand, Ferry, Butzi, Peter, etc would disagree with you. The vin plate on your car says Dr. Ing. H.C. Ferdinand Porsche not Dr. Biologie or Dr. Chemie or Dr. Physik. Don't get me wrong, I love science. The reason I love science is that engineering is the art of applying science to building things for society. Now if only everyone had a Porsche in their garage ;)
95avblm3 03-09-2013 01:35 PM
As a fellow engineer, I say, well said sir! http://forums.pelicanparts.com/support/smileys/wat.gif
kkinzli 03-09-2013 07:21 PM
Jeremy, I thought you might like that response!
Fskof 03-10-2013 07:15 AM
Wow what a great job on the car! Congrats
I hope you are enjoying the car now after all of the hard work you put in it
kkinzli 03-11-2013 05:25 AM
Thanks! I am certainly enjoying it as much as I can! I have a few odds and ends to finish up but it is drivable.
kkinzli 03-21-2013 05:46 PM
I have driven the Rat three days this week so far and am shooting for 4 tomorrow!! LHF here I come! I am contemplating getting a CDI box and matching coil so I have a fatter spark. Any suggestions on the conversion? I know I will have issues with the tach and will need a tach adjuster. I am pretty sure that you can't use the current set up I have, which is points and condensor. I have also been thinking about new ignition wires. Any suggestions?
LJ851 03-21-2013 07:39 PM
MSD cdi boxes will trigger off your points, no problem.
kkinzli 03-23-2013 02:39 PM
I am trying to get an original Bosch 3 pin CDI box. I am pretty sure that means I will need to get a new tach unless I can use a tach adaptor. Has anyone been able to adapt a non CDI tach to work with a CDI box?
