SC Cab
How bad is it? newbie question
Just found a little problem with my 89 cab. How bad is this? Is it safe to drive?
Old 02-25-2012, 05:15 AM
Get it fixed. Use wevo mounts.
Old 02-25-2012, 05:19 AM
Oh Haha's Avatar
WEVO has new, stronger mounts that can be welded in.
You can drive it without risking your safety but I would not drive it hard and get it repaired ASAP so as to not cause any more damage.
You COULD remove the sway bar altogether until you get the mount repaired. Your handling will be compromised but it will be driveable.
It seems Buckley has introduced a mount as well.http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSshk_pg9.htm
Pacific Blue
Wayne
Old 02-25-2012, 05:20 AM
tobluforu's Avatar
If that is your swaybar mount then yes it is ok, but I would get under and remove it. Now, take it easy around turns because the car wil not handle the way you are use to. You will need new ones, of course, so get wevo's.
SC Cab
thanks
thanks for the advice! I'll get right on it. it looks like the drivers side has already been worked on
Old 02-25-2012, 06:42 AM
SC Cab
my other mount looks ok should i leave it alone or replace both at the same time?
Old 02-25-2012, 02:12 PM
Your car is safe to drive although it is a good idea to remove the rear bar asap. You can drive it until the mount is repaired though as stated the car will not handle great. Specifically the car will undrsteer and will feel like it doesn't want to turn. Several options for repair/replace but should be done by a shop as you need welding done.
Old 02-25-2012, 02:44 PM
this is common failure, try to find a shop that will do a nice job e.g. rust proofing/painting of the final weldment, maybe someone can mention a good local shop with P-car experience
Sold: 1989 3.2 coupe, 112k miles
Old 02-25-2012, 04:49 PM
Use wevo mounts.
Old 02-25-2012, 05:02 PM
I'd replace the sway bar rubber bushings while you're at it.
That side looks fine. Up to you though, your call.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 02-25-2012, 09:15 PM
I was very satisfied with the job done by a muffler shop. These guys know how to prep, weld and rust proof since that's what they do and it's all done without the Porsche price tag.
Old 02-25-2012, 11:08 PM
NeedSpace's Avatar
Is it me or does the bushing on the repaired side look a little worn? Shouldn't that gap not be there? Perhaps it is simply due to the other side not being properly attached, but I would replace that bushing while I was at it.
Old 02-26-2012, 06:11 AM
I've done both on my '88. Did not use the Wevo's but I think a newer more robust one. I'm still new to the area so would be interested in knowing who you get to do the work. Thanks, Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 02-26-2012, 08:15 AM
It looks like the mount nuts have just stripped out. You might be able to use bigger bolts and a tap to repair.
-Andy
Old 02-26-2012, 10:54 AM
SC Cab
so here is the update... I'm a failure..... It sounded like simple process, jack the car up (check), tires off (check), pb blast soak the bolts (check), remove bolts (fail), i tried socket wrench, breaker bar, impact hammer, resoak, drink beer, repeat process, no go.
I really wanted to get it off so I could know if i neede new bushings as well, oh well,
any bright ideas?
Old 02-27-2012, 10:36 AM
Porchcar guy's Avatar
Heat with a torch and more PB Blaster ?
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 02-27-2012, 12:43 PM
I just went through the same thing this weekend on my 84 Targa. I could not get off the one bolt where the sway bar attaches to the drop link. If this is your problem, you'll need two 19mm wrenches. And don't be afraid to push on one with your foot. Sounds strange, but we got mine loosened in that manner.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-27-2012, 01:02 PM
More PBB and a cheater pipe on that breaker bar. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 02-27-2012, 01:11 PM
NeedSpace's Avatar
Had a similar problem myself. PB Blaster overnight, then heat the metal where it screws in, not the bolt itself. I took a 8 foot pipe to extend the wrench. Good luck!
Old 02-27-2012, 03:39 PM
SC Cab
restored hope
I'm going to give it another go. I jacked it back up after driving it a little. back to the overnight parts soak and Ill be bringing a torch and a long bar for good measure. we will see how it goes tonight, I'm just going to have to laugh if it all catches fire from the PB blast
Old 02-28-2012, 09:58 AM
